Pulsating Air Flow Equipment Selection
The discussion focuses on selecting a valve for oscillating airflow at a specific frequency for a mechanical engineering thesis on CPU cooling. A simple knife gate valve controlled by a saw tooth input is desired, with suggestions leaning towards solenoid valves for basic on/off control. However, experts recommend considering a proper control valve with a positioner for more accurate pressure or flow control, despite potential higher costs. The user is conducting experiments with compressed air and vortex tubes to enhance cooling efficiency, emphasizing the importance of valve selection at this early stage. The conversation highlights the need for clarity on control requirements to make an informed decision.
Ksum006
Hi all,
I was looking for a way to oscillate airflow at a particular frequency as fed from an electrical input.
All I'm really looking for is a simple knife gate valve that opens and closes from a saw tooth (rectangular wave) input from an oscilloscope.
I was thinking a Solenoid valve from SMC would do it.
Can you guys suggest or recommend a type of valve that would give me pulsating air flow?
Thanks
Hi Ksum. If you're looking for control over either pressure or flow, then I'd suggest a proper control valve with positioner. If that's too expensive, then look into other methods. But a proper control valve should always be the first choice when you need to actively control some variable like pressure or flow.
If you don't need to accurately control pressure or flow, you can try a two position (open/closed) solenoid valve, but then you'll be at the mercy of how fast it opens and closes and how it's flow varies as it's doing that. It'll be more of a step change depending on how closely you're looking at your measurement.
It would help if you could explain better what you're trying to accomplish (ie: are you controlling pressure, flow, temperature, other, and how fast - what do you want that measurement to look like over time?).
Ok, just quickly, I am a fourth year mechanical engineering student doing his thesis on electronic cooling.
My project is on enhansing CPU cooling through the use of pulsating impinging jets. I'm trying to set up a rig where I can do some experiments. I am planning to use a compressed air line with supply around approx. 6 to 6.5 bar. Attached to this line will be the valve that I was asking about and this valve will administer the flow to a vortex tube.
I'll have to run quite a few simulations using this rig and some IR cameras to understand and model the heat flow from the cpu during normal operation to try and set a base line. And then eventually design a cooling method to suit.
Im just not 100% certain about my valve selection at such an early stage and was looking for advice.
Thanks Q_Goest. :)
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
