Pushing a ball vs Punching a ball
  • Thread starter Thread starter aerosmiths
    Ball
Pushing a ball and punching a ball differ in how they apply force, affecting the ball's acceleration and speed. According to Newton's Second Law, both methods can yield different accelerations based on the force applied. When considering impulse, which relates to momentum change, a punch may deliver a more forceful impact over a shorter time, potentially causing the ball to travel faster. The discussion emphasizes the importance of understanding force, mass, and the resulting acceleration in both scenarios. Clarification on the calculations for punching is needed to fully compare the two methods.
aerosmiths
Is there any difference between pushing a ball and punching a ball?
If so, which one would cause the ball to travel faster?
Assume force and mass is constant.
F=ma
Pushing a ball (without friction)
Let's say F=10N and m=0.1kg
Using Newton's Second Law
a=100m/s^2
Punching a ball (without friction)
I am stuck already. Please advice me step by step. Thank you.
for punching, use the impulse ...
I = F = integral(dp/dt)
p is momentum
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
