Pushing a box across horizontal surface
In a physics lab experiment, a 6.25 kg box is pushed across a flat surface, requiring calculations for the applied force under different conditions. When moving at a constant speed of 0.400 m/s, the applied force equals the frictional force of 7.35N, as net force is zero. If the box accelerates at 0.160 m/s², the net force is 1N, leading to an applied force of 2.215N after accounting for friction. On the moon, the weight of the box and the frictional force decrease due to lower gravity, resulting in an applied force of 1.215N at constant speed and 2.215N when accelerating. Understanding the relationship between applied force, friction, and net force is crucial for solving similar physics problems.
Chandasouk
In a physics lab experiment, a 6.25 kg box is pushed across a flat table by a horizontal force F
If the box is moving at a constant speed of 0.400 m/s and the coefficient of kinetic friction is 0.120, what is the magnitude of F?
What is the magnitude of F if the box is speeding up with a constant acceleration of 0.160 m/s^2?
How would your answer to part (A) change if the experiments were performed on the moon, where g_m = 1.62 m/s^2?
How would your answer to part (B) change if the experiments were performed on the moon, where g_m = 1.62 m/s^2?
For part A, I found the weight of the block which was -61.25N and since it is on a horizontal plane Fn=mg, so Fn = 61.25N
I used the mew k being 0.120 and did
(.120)(61.25N) = 7.35N
What am I supposed to do with the constant speed it gives me? I know if something moves with a constant speed/velocity, the net force is zero...
The net force is the sum of all the forces acting on an object. In the case of constant velocity, the acceleration is 0, which says that there are NO unbalanced forces acting on the object.
Therefore, the applied force that pushes the box must be canceled out by the force of friction of an equal magnitude in the opposite direction.
Since you've calculated the force of friction, and Fnet = 0, and Fnet = Fapp - Ff, calculate the applied force!
Applied force would then be 7.35N.
Okay, onwards to the second part. What is the magnitude of F if the box is speeding up with a constant acceleration of 0.160 m/s^2?
Would I do
F = ma
F=(6.25)( 0.160 m/s^2) = 1N ?
For some reason, I think that is incorrect.
If the box is accelerating, its net force would be greater than zero.
In this case, you're right, Fnet=(6.25)( 0.160 m/s^2) = 1N.
Therefore, the NET force is 1N. However, net force also means that there is an unbalanced force acting on it, so 1N = Fapp - Friction (because since the object is accelerating, the applied force must be greater).
Since you know the value of friction, sub it into the equation 1N = Fapp - Ff.
EDIT: To find the value of the applied force.
Okay, with that clarified. The next two seem easy?
The weight of the object would be (6.25)(1.62)=10.125N
Frictional Force would be (.120)(10.125)=1.215N
Thus,
Fnet = Fapp - Ffr
0=Fapp-1.215N
Fapplied = 1.215N
and that is our answer for part C
Part D
F=ma
1N = Fapplied - Ffr
1N=Fapplied - 1.215N
Fapplied = 2.215N
Thus,
Fnet = Fapp - Ffr
0=Fapp-1.215N
Fapplied = 1.215N
Part D
F=ma
1N = Fapplied - Ffr
Fapplied = 2.215N
Precisely.
All you have to do now is understand this concept 100% so you can find your way out of more sophisticated questions.
I guess the main thing I have to remember is F =ma is for Fnet which is the sum of all forces. In this particular problem, the verticxal axes cancel each other out so the only forces acting are the horizontals which consist of Fapplied and F-friction. Therefore i can set up like so
ma=Fapplied-Ffriction
