Q Find the curve whose polar subtangent is constant
The discussion focuses on finding the curve whose polar subtangent is constant, leading to the identification of the reciprocal spiral as the solution. The initial calculations presented by the user involve rearranging and solving a polar equation, but a mistake is identified in the approach to solving for r. The correct method emphasizes solving for r directly rather than rcos(θ). Ultimately, the correct form of the reciprocal spiral is confirmed as r(θ - α) = c, clarifying the path to the solution. Understanding the differentiation and rearrangement of terms is crucial for arriving at the correct answer.
himanshu121
I have done this thing::
\frac{rsin(\theta)}{k}= - \frac{r+tan(\theta) \frac{dr}{d\theta}}{-rtan\theta + \frac{dr}{d\theta}}
Rearranging and solving i got
rsin \theta \frac{d(rcos\theta)}{d\theta}=-k\frac{d(rsin\theta)}{d\theta}
on further solving i got
rcos\theta= -kln(rsin\theta) +c
But the answer at the back is ::
:: The Reciprocal Spiral ::
:: r(\theta - \alpha) = c::
Where I went wrong ::Pls Help
It seems like you have made a small mistake in your calculations. The correct solution for the curve with constant polar subtangent is indeed the reciprocal spiral, which can be written as r(\theta - \alpha) = c.
To get to this solution, you need to start with the equation you have rearranged and solved:
rsin\theta \frac{d(rcos\theta)}{d\theta}=-k\frac{d(rsin\theta)}{d\theta}
But instead of solving for rcos\theta, you need to solve for r, as the equation for the reciprocal spiral is in terms of r, not rcos\theta.
So, let's start with your equation and solve for r:
Dividing both sides by rsin\theta, we get:
\frac{d(rcos\theta)}{d\theta}=-k\frac{d(rsin\theta)}{d\theta} \cdot \frac{1}{rsin\theta}
Using the product rule for differentiation, we can rewrite the left side as:
\frac{d(rcos\theta)}{d\theta}=cos\theta \cdot \frac{dr}{d\theta} - r\sin\theta
And the right side can be rewritten as:
-k\frac{d(rsin\theta)}{d\theta} \cdot \frac{1}{rsin\theta} = -k \cdot \frac{d(sin\theta)}{d\theta} \cdot \frac{1}{sin\theta} - k \cdot \frac{d(r)}{d\theta} \cdot \frac{1}{r}
Combining these, we get:
cos\theta \cdot \frac{dr}{d\theta} - r\sin\theta = -k \cdot \frac{d(sin\theta)}{d\theta} \cdot \frac{1}{sin\theta} - k \cdot \frac{d(r)}{d\theta} \cdot \frac{1}{r}
Next, we can rearrange this equation to solve for dr/d\theta:
cos\theta \cdot \frac{dr}{d\theta} + k \cdot
