QM - free particle in one dimensional dpace
skrat
A particle in one dimensional space, $$H=\frac{p^2}{2m}$$ in time ##t=0## has a wavefunction $$
\psi (x)=\left\{\begin{matrix}
\sqrt{\frac{15}{8a}}(1-(\frac{2x}{a})^2) &,|x|<\frac a 2 \\
0 & , |x|>\frac a 2
\end{matrix}\right.$$
a) Calculate the expected values of ##x##, ##x^2##, ##p##, ##p^2## and ##xp+px##.
b) Calculate commutators ##[H,x]## and ##[H,p]##.
Operators ##x## and ##p## in Heisenberg representation are described as ##x_H (t)=e^{i\frac H \hbar t}xe^{-i\frac H \hbar t}## and ##p_H(t)=e^{i\frac H \hbar t}pe^{-i\frac H \hbar t}##.
c) Show ##[x_H(t)]^2=[x]^2_H(t)##
d) Write operator ##x_H(t)## as combination of operators ##x## and ##p##. Hint: Calculate ##\frac{d}{dt}x_H(t)## and ##\frac{d}{dt}p_H(t)##
a) A lot of work to do here. I won't write down all the integrals and everything. My question here, and a very important one, is if there is a simpler and faster way of getting these results? (Could my ##\psi ## in any way be written as a superposition of Harmonic oscillators where I could than use annihilation and creation operators to get those results faster? Or can I maybe use Heisenberg presentation?)
I calculated this using integrals:
$$<x>=\int _{a/2}^{a/2}\psi ^2xdx$$ Note that ##\psi## is not complex. This brings me to ##<x>=0## because all the exponents are odd numbers. I checked all the integrals using Mathemathica so let's just assume I got this part of the problem right.
b)
##[H,x]=\frac{1}{2m}[p\cdot p,x]=\frac{1}{2m}[p[p,x]+[p,x]p]## where ##[p,x]=-i\hbar\frac{\partial }{\partial x}x+i\hbar x \frac{\partial }{\partial x}##. I how NO idea why the second term is 0? Is that because there is nothing to calculate the derivative of?
Well, when that is answered, the result is ##[H,x]=-\frac{i\hbar p}{m}##
About ##[H,p]=\frac{1}{2m}[p^2,p]## it is obvious that they commutate, therefore ##[H,p]=0##.
c)
##x_H^2(t)=e^{i\frac H \hbar t}x\cdot x e^{-i\frac H \hbar t}=e^{i\frac H \hbar t}xe^{-i\frac H \hbar t}e^{i\frac H \hbar t}xe^{-i\frac H \hbar t}=[x_H(t)]^2##
d)
I don't understand this part at all.
##\frac{\mathrm{d} }{\mathrm{d} t}x_H(t)=\frac{iH}{\hbar}e^{i\frac H \hbar t}xe^{-i\frac H \hbar t}-e^{i\frac H \hbar t}x(-\frac{iH}{\hbar})e^{-i\frac{H}{\hbar} t}=\frac{i}{2\hbar m}(p^2e^{i\frac H \hbar t}xe^{-i\frac H \hbar t}+e^{i\frac H \hbar t}xp^2e^{-i\frac H \hbar t})##
Now what can I do with this? o_O
It is not zero. In general it will act on a function f. However, this also goes for the other term where you get the derivative of x times f, on which you can use the product rule.
If you express the time derivative of x in terms of the commutator with the Hamiltonian, what do you get?
Aaaa, that is some good thinking...
##[p,x]f=-i\hbar \frac{\partial }{\partial x}xf+i\hbar x \frac{\partial }{\partial x}f=-i\hbar(f+x{f}')+i\hbar x{f}'=-i\hbar f##. Simple as that. =)
Aham, $$\dot{x}_H(t)=\frac i H[H,x](t)=\frac{p(t)}{m}$$ and $$\dot{p}_H(t)=\frac i H[H,p](t)=0 \Rightarrow p_H(t)=p_{H_0}=p$$ and than $$x_H(t)=\frac{p}{m}t+x_{H_0}=\frac{p}{m}t+x$$ I guess this is the answer than?
Yes, note how it corresponds very nicely to the classical ##x(t) = vt + x_0##.
Likes skrat
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
