Chopin
- 367
- 13
Hi all. I'm taking my first foray into QFT, and have a question which is hopefully pretty basic. I think I understand the concept itself, I just don't quite get how the math works out.
I'm right at the beginning, in the discussion of how to set up the creation/annihilation operators for a spin-0 field. The text starts with the Klein-Gordon equation:
(\partial^2 + m^2)\varphi(\textbf{x}, t) = 0
A real-valued solution to this equation is a combination of plane waves:
\varphi(\textbf{x}, t) = a\textit{e}^{\textit{i}\textbf{k}\cdot\textbf{x}-{\omega}t} + a^{*} \textit{e}^{-\textit{i}\textbf{k}\cdot\textbf{x}+{\omega}t}
Where \omega = +\sqrt{\textbf{k}^2 + m^2}. Next, we try to generalize this by summing over all possible momentum vectors. A naive solution would be this:
\varphi(\textbf{x}, t) = \int{d^3\textbf{k}\:a(\textbf{k})\textit{e}^{\textit{i}\textbf{k}\cdot\textbf{x}-{\omega}t} + a^{*}(\textbf{k})\textit{e}^{-\textit{i}\textbf{k}\cdot\textbf{x}+{\omega}t}}
But this isn't Lorentz invariant. I think I get that--the Lorentz transform will change the size of the volume element, sort of like what happens when you take a volume integral in spherical coordinates. Is that correct?
To get around this, we do the following:
\varphi(\textbf{x}, t) = \int{\frac{d^3\textbf{k}}{(2\pi)^{3}2\omega}\: a(\textbf{k})\textit{e}^{\textit{i}\textbf{k}\cdot\textbf{x}-{\omega}t} + a^{*}(\textbf{k})\textit{e}^{-\textit{i}\textbf{k}\cdot\textbf{x}+{\omega}t}}
That sort of makes sense--we're basically scaling down each plane wave by its corresponding energy, which rises in proportion to the volume element as we move up the momentum scale. I don't quite understand how to show mathematically that this ends up being Lorentz invariant, though. The text basically just handwaves it, so it's no help--can anyone explain how one could arrive at that normalizing factor if one were starting from scratch?
