Solving for <Lx^2> and <Ly^2>: How do I show that <Lx^2> = <Ly^2>?
In the discussion, participants explore how to show that the expectation values of angular momentum components in the x and y directions, <Lx> and <Ly>, are both zero for a particle in an angular momentum eigenstate. They derive the relationship <Lx^2> + <Ly^2> = <L^2> - <Lz^2> and express <Lx^2> and <Ly^2> in terms of known constants, leading to the conclusion that <Lx^2> = <Ly^2>. The use of commutators is discussed as a method to demonstrate that the expectation values of <Lx> and <Ly> are related and ultimately zero. The conversation highlights the importance of operator algebra in quantum mechanics and the application of ladder operators for simplifying calculations.
J man
If a particle is in an angular momentum eigenstate, psi, show that <Lx> = <Ly> = 0, where <Lx> is the angular momentum in the x-direction.
Also show that <Lx^2> = <Ly^2> = [(h bar)^2][l(l+1)-m^2]/2
L^2 = (Lx^2)+(Ly^2)+(Lz^2)
I began by rewriting my relevant equation as:
<Lx^2>+<Ly^2>= <L^2>-<Lz^2>
I then applied previous knowledge to rewrite the right side as
<Lx^2>+<Ly^2>= (h bar^2)l(l+1)psi-(h bar^2)m^2 psi
I'm then able to rewrite this as the second desired "show that" in the problem, I just have no idea how to apply this to the first. I understand that if I can show the right hand side is zero, <Lx^2> must equal <Ly^2> which would be zero, but I don't know why or how to show that part to prove part A. Thanks.
What about using the commutator [L_x,L_z]=... and calculating its expectation value in an eigenstate of L_z. Perhaps you will be able to deduce something from this?
Okay...so I'm trying to work this out, and these are my steps:
I know (Lz) psi = (h bar)m psi
so expectation value of the commutator would be:
<psi|(Lx)(Lz)-(Lz)(Lx)|psi> = <psi|(Lx)(Lz)|psi>-<psi|(Lz)(Lx)|psi>
= <(Lx)psi|(Lz)psi>-<(Lz)psi|(Lx)psi> = <(Lx)psi|(h bar)m psi>-<(h bar)m psi|(Lx)psi>
from that point I'm not sure exactly where to go. Would that last expression be equal to -i(h bar)(Ly)?
OR would it be equal to zero if Lx is hermitian?
Do you know how to express L_x and L_y in terms of the ladder operators L_\pm? That's the easiest way to compute expectation values.
Edit: The two expectation values on the RHS in post 3 are real and equal because L_x is Hermitian. Can you relate that calculation to one of the expectation values that you wanted to compute?
Well, looking back at my notes the only instances in class in which we used ladder operators were in calculating energy level differences, eigen-values and in re-writing L^2 as a function of the L+/- operators and Lz.
The simplest way would seem to be writing L+/- = Lx +/- i Ly, then solving for Lx and Ly, would I think plug that into the commutator for the expectation value?
No, just plug it into the expression for <Lx> directly.
Okay, so referring to the non-ladder method, is the association I was supposed to make that the expectation value of the commutator of Lx, Lz should be equal to the expectation value of i (h bar) Ly which just reduces to the constants multiplied by the expectation value of Ly which would then be zero?
You could conclude the expectation values are related by a constant, but you couldn't say yet that they're both 0.
Okay, I was trying to apply my calculation of the expectation values of the commutator, which I found to be 0, with the expectation value of the normal commutator result, i(h bar)Ly. In which case, the i and h bar drop and I'm left with <Ly>=0. Is this not correct?
Sorry, you're right. I didn't think about it too carefully.
Thank you everyone. I've been having a hard time getting used to operator algebra so this is appreciated.
