I Quantum Computing - projection operators
Peter_Newman
Assume ##P_1## and ##P_2## are two projection operators. I want to show that if their commutator ##[P_1,P_2]=0##, then their product ##P_1P_2## is also a projection operator.
My first idea was:
$$P_1=|u_1\rangle\langle u_1|, P_2=|u_2\rangle\langle u_2|$$
$$P_1P_2= |u_1\rangle\langle u_1|u_2\rangle\langle u_2|\neq 0$$
the second expression is not zero if ##\langle u_1|u_2\rangle## are not orthononal.
But I do not really get on with this task, which is why I hope for some advice.
An expression like ##P_1 = |u_1\rangle\langle u_1 |## is for a projection operator that projects any vector on a 1-dimensional line in the state vector space. A more general projection is
##P = \sum\limits_{k} |u_k \rangle\langle u_k |##
where the vectors ##|u_k \rangle## form an orthonormal set.
Likes vanhees71
You're not trying to show that the second expression is zero. You're trying to show that ##P_1 P_2## is a projection operator if ##P_1## and ##P_2## commute.
Do you know what defines a projection operator? That is, if ##P## is a projection operator, can you write down a statement that must be true of it (without writing it out in terms of bras and kets)?
My knowledge of projection operators is similar to what @hilbert2 summarized in his post. I somehow lack the relation to the commutation operator. It would be very nice if you could help me a bit.
So the commutator operator comes to mind. At least I have snapped that at some point:
$$[A,B]=AB-BA$$
So suppose I have the two projection operators ##P_1## and ##P_2##. Since these are orthogonal, the product of these two is 0, which I wanted to say in my first post. But now the connection to what is missing in the task of my input posts (##P_2P_1## would also have to be 0 and therefore can not be a projection operator?).
Did you know that a projection operator ##P## has the property that ##P^2 = P##? In other words, applying it twice is the same thing as applying it once. (This should make sense if you think about what a projection operator means.)
Can you see how this fact might be helpful?
No, that's not true. ##[P_1, P_2] = P_1 P_2 - P_2 P_1##. So ##[P_1, P_2] = 0## just implies ##P_1 P_2 = P_2 P_1##. It does not imply that ##P_1 P_2 = 0##.
The problem statement does not require that ##P_1## and ##P_2## are orthogonal.
Ok, that would have been my alternative hypothesis.
Yes, I have heard of this property before. Unfortunately, I can not quite see how far this property can help me with ##P_1 P_2 = P_2 P_1##
What does ##P^2 = P## look like if ##P = P_1 P_2##?
If ##P=P_1P_2## so ##P^2=(P_1P_2)(P_1P_2)=P_1^2P_2^2##
Peter_Newman said:
If ##P=P_1P_2## so ##P^2=(P_1P_2)(P_1P_2)##
Right.
Peter_Newman said:
##(P_1P_2)(P_1P_2)=P_1^2P_2^2##
How are you obtaining this? The ordering of the factors on the LHS is different than on the RHS, since ##P_1^2 = (P_1 P_1)## and ##P_2^2 = (P_2 P_2)##.
##P^2=P_1P_2P_1P_2=P_1^2P_2^2=P_1P_2=P##
Ok, so does this answer your question in the OP?
Yes, almost. I just do not quite know how to express that linguistically ...
Why do you need to? The equations are clear and straightforward.
Likes vanhees71
Yes, I agree with that a bit, if I see ##P^2=P_1P_2P_1P_2=P_1^2P_2^2=P_1P_2=P##
Here is the above mentioned product already in it ...
@PeterDonis by the way, thanks for the support!
Likes vanhees71
You're welcome!
