What are the best ligands for PbS quantum dots in solar cell applications?
The discussion focuses on the challenges of ligand exchange for PbS quantum dots, particularly for non-polar solvents like toluene and chlorobenzene, with an application in solar cells. The user seeks guidance on suitable ligands, emphasizing the need for short ligands that promote efficient charge transfer while maintaining colloidal stability. Previous attempts with amine and carboxylic acid ligands have been unsatisfactory, and while thiol ligands are suggested as a potential solution, the user expresses concerns about their handling. Key points include the importance of ligand functionality and the impact of ligand choice on nanoparticle aggregation and performance in solar cell applications.
yfir
Hi everyone,
I'm working with quantum dot (PbS). However, I'm actually not a chemist, so could anyone help me to address some issues regarding quantum dots especially related to ligand exchange process. My questions are:
1. anyone can address about what kind of functionality (e.g: thiol, acid, amine, etc) basically suitable for what nanoparticle?
2. For PbS quantum dots, could you suggest me what is the best ligand to used? especially if the quantum dot size relatively small (~2-3 nm).
thanks,
yfir
Chemistry news on Phys.org
That would depend on what solvent you intend to use and what use you intend for the particles. Xanthates like ethyl xanthate react with the surface of PbS and dithiophosphates have been used to treat sulfide minerals in froth flotation applications.
Ah yes, Sorry, I should be more specific. The solvent used are the non-polar one such as Toluene and chlorobenzene. I will need it for solar cell application whereas normally the new ligand needed are the short one which allow efficient charge transfer and at the same time give stability of the colloidal QD. The latter one is the main problem of ligand exchange, because in most cases for small nanoparticle size, the QDs after ligand exchange tends to be aggregated. I have tried with amine and carboxylic acid ligands. However, the results haven't been satisfying. I was told that thiol ligands could be a good alternative, but I try to avoid this as most of this molecule are not really pleasant to handle. That is why I would like to know if any of you could give me at least "guidance" to choose the suitable ligand.
Thanks,
yfir
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
