Quantum: Photon strikes Electron.
A 120nm photon collides with an electron, causing the electron to move forward while the photon rebounds. The discussion involves calculating the initial speed of the electron and the wavelength of the rebounding photon using relevant equations. Initial attempts at solving the equations led to incorrect results due to algebraic errors and unit inconsistencies. After identifying the mistakes, the correct approach involved using the quadratic formula for accurate calculations. The problem emphasizes the importance of careful algebraic manipulation in physics problems.
Yashir1992
A 120nm photon strikes an electron in a head on collison causing the elctron to be moved in the forward direction and the photon to rebound directly back.
A. Calculate the inital speed of the Electron after colison.
B. Calculate the wavelength of the rebounding Photon.
E=H/f
E = W+Ek
p= H/Wavelength
Givens: C= 3.0x10^8m/s
H = 6.63x10^-34J*S
Although the problem being linear simplifies it a bit, i still had trouble with it. so here i go.
Equation one.
E(prime)= HC/Wavelength - 1/2mv^2
HC/Wavelength(prime) = HC/Wavelength - 1/2mv^2
Equation two.
HC/Wavelength(prime) = -HC/Wavelength + Cmv
Therefore
HC/Wavelength - 1/2mv^2 = -HC/Wavelength + Cmv
Rearranged this makes: (some parts already calculated for simplicity sake)
3.32x10^-8J / (c)(m^2)(2) = v+v^2
3.32x10^-8J / 4.98x10^-52 = v+v^2
6.67x10^59 = v+v^2
Squareroot(6.67x10^59/2) = v
5.77x10^29 = v
But this answer must be wrong since its going way faster then the speed of light.
maybe some clarification on where i went wrong or if i made some silly math error would be awesome.
Your first two equations look good, but something went awry after you rearranged. The right side isn't correct because the units don't work out. You can't add v to v^2. There's probably a factor of c missing. Not surprisingly, the units on the left side look messed up too.
Your setup looks good, but I think you made an algebra mistake somewhere.
Yeah, iv just figured out that you had to use a Quadratic formula instead of rearanging. i found my mistake and corrected it and answered the question the right way, but thanks for taking a look at it.
