Quantum physics and wave lengths
The discussion revolves around calculating the de Broglie wavelength of an electron accelerated through a potential difference of 1 MV, emphasizing the need to use relativistic mass and energy expressions due to the high energy involved. The correct answer is given as 8.7 x 10^-13 meters. Participants suggest starting with the de Broglie wavelength formula, λ = h/p, and highlight the importance of determining the relativistic mass and momentum. The conversation also points out that the kinetic energy can be equated to the energy gained from the potential difference to find the electron's velocity. Understanding these concepts is crucial for solving the problem accurately.
poohead
What is the de Broglie wavelength of an electron that has been accelerated through a potential difference of 1 MV ( you must use the relativistic mass and energy expressions at this high energy.)
ans. 8.7 x 10^-13
M= Mo/ square root (1 - v^2/c^2)
I have no idea where to go with this question i am completely stumped, can someone please steer me in some direction to understanding such and getting the right answer, thank you and i really appreciate it.
The question offers plenty of clues of where to start.
The desired answer is the de Broglie wavelength. Therefore, you could start at the end and work backwards. Do you know any equations for the de Broglie wavelength that might help you solve the problem? I know one that sticks out immediately; this equation relates the wavelength to only one other variable. Once you determine what this variable is, can you link it to the given data of the problem? If so, then problem solved.
well i assume now you use wavelength= h/mv and to find v i'd use Ee=Ek, just i need to find relativistic mass and energy first for the speed ill get is faster then that of light
Here is an important difference for the momentum: p = mv (non-relativistic), p = \gammamv (relativistic).
De Broglie's original formula is
\lambda = \frac{h}{p}
