How Does Time Evolution Affect Quantum Measurement Probabilities?
The discussion focuses on a quantum system with a Hamiltonian H and its eigenstates, exploring the effects of time evolution on measurement probabilities. The operator Q has eigenvalues 1 and -1, with corresponding normalized eigenstates ζ1 and ζ2 derived from the energy eigenstates. After measuring Q and obtaining a result of 1, the probability of measuring 1 again after a time T = πħ/(E2 - E1) is shown to be 0, but this is only true at that specific moment. The participants clarify that while the probability is zero at time T, it does not remain zero indefinitely, as the system will continue to evolve and the probabilities will cycle. The conversation emphasizes the importance of understanding time evolution in quantum mechanics and its impact on measurement outcomes.
mcheung4
A quantum system has Hamiltonian H with normalised eigenstates ψn and corresponding energies En (n = 1,2,3...). A linear operator Q is defined by its action on these states:
1 = ψ2
2 = ψ1
n = 0, n>2
Show that Q has eigenvalues 1 and -1 and find the corresponding normalised eigenstates ζ1 and ζ2, in terms of energy eigenstates. Calculate <H> in each of the states ζ1 and ζ2.
A measurement of Q is made at time=0, and the result 1 is obtained. The system is then left undisturbed for a time t, at which instant another measurement of Q is made. What is the probability that the result will again be 1? Show that the probability is 0 if the measurement is made after a time T = \piħ/(E2 - E1), assuming E2 - E1> 0.
I found
ζ1 = (ψ1 + ψ2)/√2
ζ2 = (ψ1 - ψ2)/√2
and <H> = (E1 + E2)/2 for both.
I have trouble doing the second part.
Doesnt the system collapse into ζ1 given we know this is the state at time =0?
so probability will be 1?
The wave function collapses to \zeta_1 after measurement but after that, it will evolve by Schrodinger equation and so it will change gradually. You should apply the time evolution operator to the state \zeta_1 and then calculate the inner product of the evolved state with \zeta_1.
so ψ(x,0) = (ψ1 + ψ2)/√2,
and U(t,0) = exp(-iHt/ħ),
then ψ(x,t) = U(t,0)ψ(x,0) = exp(-iHt/ħ)(ψ1 + ψ2)/√2
inner product :
∫ [exp(iHt/ħ)((ψ1)* + (ψ2)*)/√2][(ψ1 + ψ2)/√2] dx
= exp(iHt/ħ)
is this correct? but i don't know what H is here, is it (E1+E2)/2?
inner product :
= exp(iHt/ħ)
The point you're missing, is how to act on \psis by the evolution operator.
<br /> e^{\frac{iHt}{\hbar}}\psi_n=\sum_{m=0}^{\infty} (\frac{iH_nt}{\hbar})^m \frac{ \psi_n}{m!}=\sum_{m=0}^{\infty} (\frac{it}{\hbar})^m \frac{H^m \psi_n}{m!}=\sum_{m=0}^{\infty} (\frac{it}{\hbar})^m \frac{E_n^m \psi_n}{m!}=\sum_{m=0}^{\infty} (\frac{iE_nt}{\hbar})^m \frac{ \psi_n}{m!}=e^{\frac{iE_n t}{\hbar}}\psi_n<br />
So you don't need to know H!
so ψ(0) = (ψ1 + ψ2)/√2, ψ(t) = U(t,0)ψ(0) = exp(-iHt/ħ)(ψ1 + ψ2)/√2 = [exp(-iE1t/ħ)ψ1 + exp(-iE2t/ħ)ψ]/√2. then find the probability amplitude of (ψ1 + ψ2)/√2 in this time-varying state by taking the inner product ((ψ1 + ψ2)/√2 , ψ(t)), squared it to find the probability = [1 + cos((E2-E1)t/h)]/2, then sub in T = pi*h/(E2-E1) indeed got probability = 0. but why after T it'll stay 0? doesn't it cycle again by the consine term?
Why do you say it remains zero? Just because it becomes 0 momentarily does not mean it stays at 0.
I think you simply misread the question but I can see how the phrasing may lead to confusion. What they meant is that at the time T = pi*h/(E2-E1) after the initial measurement was made the probability is zero, but they do not mean to say that it will remain zero for all times after that instant. They really just meant at that specific instant, not at all later times. So you are right, it will cycle again.
ok thanks guys!
