Quartic with complex coefficients
ab959
I am trying to solve a fourth order polynomial which is in the following form
x^4+Ax^3+(B_1+B_2p)x^2-(C+Ap)x+D+Ep=0
Where A, B_1, B_2, C, D, E, are real parameters and p is a complex parameter.
I have investigated many ways of solving this equation however there does not seem to be much information regarding complex coefficients. My solution is very messy for real coefficients but it still exists and I derived it using Ferrari's method. I am not sure if I can use this method in the case where p is complex.
Any suggestions will be much appreciated.
Yes, Ferrari's method works for both real and comples coefficients.
OK great thanks I realized this soon after I posted. What I am more interested in knowing is if you classify the roots in terms of the parameters. I.e. knowing when there will be 4 real roots or complex roots etc. My intuition tells me however that if Im(p) not equal to zero then all solutions will be complex. This is possible for real coefficients however I don't know if this can be done for complex coefficients.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
