What is the analogy between capacitor discharge and radioactive decay?
  • Thread starter Thread starter gangsta316
The discharge of a capacitor through a resistor is mathematically analogous to radioactive decay, represented by the equations Q = Q_0 e^{-\frac{t}{RC}} and N = N_0 e^{-\lambda t}. In this analogy, A in A = λN corresponds to the rate of change of the quantity, which can be expressed as dN/dt. The negative sign in the current equation I = -Q/(RC) indicates that charge is decreasing, reflecting the direction of current flow. The discussion highlights the importance of understanding how these equations relate to physical processes in both electrical and nuclear contexts.
gangsta316
The discharge of a capacitor through a resistor is analogous to radioactive decay.
Write down the equation for capacitor discharge which is analogous to A = \lambda N.
Explain the analogy between A and the subject of your equation.
The only equation I can think of is Q = Q_0 e^{-\frac{t}{RC}} and the similar ones for voltage and current but this can't be the one which is analogous to that equation because it is analogous to N = N_0 e^{-\lambda t}.
You thought of the right equation, you just need to get it in a different form. How do we get the equation N = N_{0}e^{-\lambda{t}}?
Is the A in A = \lambda N equal to \frac{dN}{dt}?
That does seem to be what the question is driving at, yeah.
Is the answer I = \frac{Q}{RC}.
I neglected the negative like they did in the question. Why do they get rid of the negative when we talk about activity? Is it because we need it when using differential equations because it is decaying but we leave it when not using the differential equation because we know it is decaying?
What does the negative in I = - \frac{Q}{RC} mean physically? Of course it tells us that charge is decreasing but does it tell us about the direction of current flow?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
