Question about Electrical Energy
The discussion revolves around the concept of electrical energy and the operation of transformers, specifically addressing the relationship between voltage, electric potential, and energy conservation. Participants explore the implications of these concepts in the context of classical mechanics and electrical circuits.
  • One participant questions how transformers can increase voltage from 200V to 15kV without an apparent expenditure of energy, drawing a parallel to classical mechanics.
  • Another participant asserts that energy is conserved in transformers and emphasizes that power is defined as the product of voltage and current, suggesting that the initial understanding of electric potential as energy is overly simplified.
  • A later reply clarifies that voltage is a measure of electric potential rather than potential energy, explaining that electric potential relates to the work needed to move a unit charge and that in circuits, the behavior of large numbers of charges complicates the relationship between voltage and energy.
  • Participants discuss the role of absolute electric potential in circuit analysis, noting that voltage is always a difference between two points.
Participants express differing views on the interpretation of voltage and electric potential, with some emphasizing the conservation of energy in transformers while others challenge the simplifications made regarding electric potential. The discussion remains unresolved with multiple competing views present.
There are limitations in the assumptions made about electric potential and energy, particularly regarding the simplification of voltage as a direct measure of potential energy. The discussion also reflects a dependence on definitions that may not be universally agreed upon.
CrazyCrux
I know that energy cannot be created nor destroyed. However, I also know that voltage is basically electrical potential energy. So, how can a transformer exist? In terms of classical mechanics, in order to increase the PE of say, a ball, you must lift it (expending energy) higher above the gravitational center of the earth. However, with transformers I don't see any immediate expenditure of energy that would allow such a drastic (200V to 15kV) increase in potential energy. Can someone explain this to me, please?
Good for you to never question conservation of energy. On this planet, energy is always conserved.
Transformers do conserve energy. But the rate of electric energy (which we call power) is V*I, voltage times current, not voltage. Your idea of electric potential as energy is a bit too simplified. Try starting here
https://en.wikipedia.org/wiki/Electric_potential
https://en.wikipedia.org/wiki/Electrical_energy
A key point, that I think you miss is that if we use a voltmeter to measure the voltage of a transformer, the voltmeter always has two wires. Voltage in an electric circuit is always the difference in potential between two points. The absolute electric potential, plays no role in circuit analysis.
I think I understand now. Thank you for the explanation.
Voltage isn't a measure of potential energy, it's a measure of electric potential. Electric potential is a measure of the work required to move a unit of charge from its current position to infinity. Notice that I said "unit of charge". If I place a particle with a charge of three coulombs in an electric field, find its electric potential energy, and then divide out the charge, I no am longer talking about the particle, but about the field. When we give a voltage, we aren't saying that every single charge is given X amount of potential energy. Instead, voltage and electric potential are properties of the field. This allows us to greatly simplify and generalize our analysis of electrical circuits.
In a simple example like a single particle in free space, it's easy to say that voltage and the potential energy of a single particle are related. However, in an electrical circuit, things change drastically. We can't point to any individual charge and say that it will expend X amount of energy. Instead we are talking about the bulk behavior of huge numbers of charges. When the number of charges is something like ##10^{20}##, the particulars of any single particle just don't matter. A charge may accelerate under the influence of the applied field for a short time and then lose all of its energy in a collision with an ion in the conductor. Or it may scatter and lose only some of its energy. Or it might be moving the opposite way as the current flow due to its thermal motion. All of these things can be simplified down thanks to the huge number of charges we're dealing with.
  • · Replies 16 ·
  • · Replies 16 ·
