KE and U Energy in Spring Gun Question
  • Thread starter Thread starter intenzxboi
The discussion revolves around the mechanics of a child's spring gun, focusing on the spring constant, energy transfer, and the ball's launch dynamics. The key questions involve calculating the launch speed of the ball and determining the spring's initial compression distance. There is confusion regarding the final velocity at the ball's maximum height, with clarification needed on whether it should be zero. Participants also question the application of kinetic and potential energy equations, particularly regarding their components. The conversation emphasizes the importance of understanding energy conservation principles in this context.
intenzxboi
The spring in the muzzle of a child's spring gun has a spring constant of 730 N/m. To shoot a ball from the gun, first the spring is compressed and then the ball is placed on it. The gun's trigger then releases the spring, which pushes the ball through the muzzle. The ball leaves the spring just as it leaves the outer end of the muzzle. When the gun is inclined upward by 33° to the horizontal, a 50 g ball is shot to a maximum height of 1.75 m above the gun's muzzle. Assume air drag on the ball is negligible. (a) At what speed does the spring launch the ball? (b) Assuming that friction on the ball within the gun can be neglected, find the spring's initial compression distance.
i know how to solve it but my question is:
1/2 m (Vf^2 - Vi^2)= - mgh
the teacher put vf^2 = Vi cos 33
but I am wondering isn't Vf= 0 when it reaches the top??
Does KE and U energy have a components like forces??
and for part b)
1/2 k x^2 = 1/2 mv^2
correct??
anyone??
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
