Is Electric Potential Simply a Measure of Volts Per Unit Charge?
  • Thread starter Thread starter square_imp
    Potentials
Electric potential, measured in volts, is indeed a measure of volts per unit charge, defined as work done per charge. The discussion clarifies that electric potential energy and electric potential are distinct concepts; the former is expressed in joules while the latter is in volts. The relationship between these quantities is illustrated through the equation Work done = -q∆V, highlighting how changes in potential energy relate to electric potential. Understanding this distinction is crucial for accurate application in physics equations. Overall, the conversation emphasizes the importance of differentiating between electric potential and electric potential energy.
square_imp
Can someone just confirm the following:
Change in potential energy of a charge, for example caused by moving two negative charges together is equal to the work done:
Work done = Force x Distance
= -qE * ∆X (Where E is electric field strength)
= -qE∆X
= -q∆V
Which therefore is a different quantity to the electric potential we know as simply Volts, which is (Work Done)/(q). I am fine actually using these different values in equations and the like, I would just like more information about what it all means. Is electric potential (Volts) simply a measure of Volts per unit charge? Or is it more complex than that? Probably a silly question really, but just like to be clear about these things. :smile:
Exactly. The units also bear this out: 1V=1 J/C.
I think the thing you are missing is that "electric potential" and "electric potential energy" are two different things, and they must not be interchanged. The former is measured in volts, and the latter is measured in Joules.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
