What Is the Power Series and Interval of Convergence for f(x) = x/(x^2 + 1)?
The discussion focuses on finding the power series for the function f(x) = x/(x^2 + 1) and determining its interval of convergence. The approach involves rewriting the function and applying the geometric series formula, leading to a series expansion. The ratio test is suggested to establish the radius of convergence, with emphasis on checking the boundary cases. Participants share methods for calculating derivatives and evaluating the series at specific points. The conversation concludes with a participant expressing clarity on the steps needed to solve the problem.
vande060
find the power series for the function and determine the interval of convergence
<br /> f(x) = {{x} \over {x^2 +1}} <br />
im trying latex for the first time so here it is if it doesn't show well: f(x) = x/(x^2 + 1)
<br /> f(x) = \frac{\x}{2x^2 + 1} <br />
f(x) = x/(x^2 + 1)f(x) = x/(2x^2 ( 1/2x^2 + 1) )
f(x) = x/(2x^2 ( 1 - -1/2x^2 ) ) <br /> = \frac{x}{2x^2} \sum_{n=1}^{\infty} <br /> (-1/(2x^2))^n
<br /> \sum_{n=1}^{\infty} <br /> ((-1)^n x)/(2x^2)^(n+1)
once I take the limit though by using the ratio test i get 1/16x^8
I would find the power series for 1/(x^2+1) then multiply each term by x, then look at it and write the summation notation.
f(x)= f(0)+f '(0)*x +f ''(0)*x^2/2 + f '''(0)*x^3/6 +...
f(x) = (x^2+1)^-1
f '(x) = - 2x*(x^2+1)^-2
f'' (x) = -2x*-2*2x*(x^2+1)^-3 + (x^2+1)^-2*-2
f(0) = (0+1)^-1 = 1
f'(0) = 0
f''(0) = 0 -2*(1^-2) = -2
f(x), centered at 0 for 1/(x^2+1) = 1-x^2+...(I'll leave a couple more terms for you so you can see the pattern), then multiply through by x.
OR, if you've got some intuition, you could note that a/(1-r) is the sum of a geometric series for abs(r)<1, then you'd write: 1-x^2+...(still going to leave those terms for you), the multiply through by x.
You can probably write the summation by looking at the pattern of the terms.
Then you can apply the ratio test, or note from the geometric series that abs(r)<1...to get the radius of convergence. Don't forget to also check the =1 case.
f(x) = (x^2+1)^-1
f(0) = (0+1)^-1 = 1
f'(0) = 0
okay I understand what I have to do now thank you
