Understanding the Effects of Salt Water on Pressure Testing for Plastic Pieces
  • Thread starter Thread starter TrueQ06
    Pressure
When conducting pressure testing on plastic pieces submerged in salt water, the pressure experienced by the parts is influenced by both the water column and the added air pressure. A 33-foot column of salt water exerts approximately 14.7 psi, and if the chamber is open to air, the total pressure at the bottom would be 29.4 psi. If 20 psi of compressed air is introduced, the overall pressure would reach 34.7 psi, assuming the water column remains at 33 feet. The pressure exerted by the water is independent of the air pressure, as water is incompressible. Therefore, the total pressure on the plastic pieces is the sum of the water pressure and the air pressure applied.
TrueQ06
I am trying to subject some plastic pieces to temperature and pressure testing while the parts are in a container of salt water. I have a pressure chamber that is pumped to a desired pressure with compressed air.
If I put the pieces in the container of salt water in the chamber and then pump it to 20psi, will the pressure felt by the parts be 20psi, or does the salt water affect the pressure the parts feel? Does that change if I seal the container with some air above the salt water?
Thanks.
If you had a container filled with salt water 33' high the pressure at the bottom would be 14.7psi. If the container was open to the air, the pressure at the bottom would be 29.4 psi. Pumping in compressed air would result in a rise in pressure equal to the pressure of the air plus the 14.7 psi of the water.
If you pumped in 20psi of air, as you suggest, then the pressure at the bottom would be 34.7psi. Thats assuming a 33' water column. You can do the math to adjust the pressure the water adds if the column is less than 33'. For example, a water column half as high (16.5') would be (7.35psi).
If I get what you are saying, its like a ball of water in a box of air which you can pressurize?? Since water is incompressable, I think the water pressure would equal that of the air pressure assuming the 'ball' was made of flexible material.
The water exerts a pressure all by it's self, depending on the height of the water column. Any air pressuer you add on top of the water will add to the total pressure. As far as the container expanding, that is not necessary as the air is compressable.
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
