Question about speed of a projectile
  • Thread starter Thread starter vande060
    Projectile Speed
The discussion revolves around calculating the speed of a horizontally launched projectile as a function of its horizontal position, x. The equations for vertical and horizontal motion are established, with y defined as a function of time and x as a function of initial speed and time. The user attempts to express time in terms of x and substitute it into the equation for y to find the vertical velocity. They differentiate to find the velocities in both x and y directions, ultimately applying these to the speed formula. The solution process is outlined, but the user expresses uncertainty about its correctness.
vande060
1. Homework Statement
If a projectile is launched horizontally (in direction of increasing x) with initial speed v0, from a height h above the origin, find its speed s = (v^2x + v^2y)^1/2 as a function of x
2. Homework Equations
so far i have the equations for x and y
y= h - 1/2*g*t^2
x= v0*t
3. The Attempt at a Solution
i don't understand how to do this problem in the least
bump
i was thinking,
x = v0t
t = x/v0
y = h - 1/2*g*t^2
substituting for t
y(x) = h - 1/2*g*(x^2/v0^2)
differentiating to get the velocity
y(x)' = (-g*x)/v0^2
and
x' = v0
then i can put this in the formula
s = (v0^2 + [(-g*x)/v0^2]^2)^1/2
to get speed as a function of x. i don't know if this is right, but its a shot
  • · Replies 17 ·
