Question about spring compression
A 12 kg block slides down a frictionless 35-degree incline and compresses a spring with a constant of 3.00x10^4 N/m after traveling 3 m. The discussion highlights the use of the work-energy principle, specifically the equation Ws = 1/2 kxmax^2, to determine the spring's compression. It emphasizes the conservation of energy, where the gravitational potential energy of the block converts into kinetic energy as it descends and then into the spring's potential energy upon compression. Calculating the block's acceleration and velocity can also aid in understanding the dynamics involved. The key takeaway is that the total mechanical energy is conserved throughout the process.
chevyboy86
A 12 kg block slides from rest down frictionless 35 degree incline and is stopped by spring w/ constant of 3.00x10^4 N/m. The block slides 3 m from the point of release to the point of rest against spring, how far has spring compressed?
Now I know this involves the equation Ws= 1/2kxmax2, but I am not sure where to go from there.
The block starts at rest and accelerates on a frictionless plane/incline. One could determined the acceleration of the block down the incline (F/m) and the velocity at the distance traveled.
Another way to do this is to apply conservation of energy. At the beginning, the energy of the block is simply gravitational potential energy (GPE). When block to the spring, it decreases in elevation, so its GPE changes, and that changes equals the increase in kinetic energy.
When the block compresses the spring, its kinetic energy is transformed into the springs potential energy.
http://hyperphysics.phy-astr.gsu.edu/hbase/pespr.html
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
