Question about stall warning system
  • Thread starter Thread starter Boeing707
    System
The stall warning vane's precision in detecting the stagnation point on the wing is crucial for aircraft safety, particularly in the 707 variant. The lift transducer operates continuously, but the vane may not immediately reflect airflow changes as it can linger between center and full deflection. Stall warnings are designed to activate before reaching the critical angle of attack, typically 2-3 degrees earlier, though this can vary based on flap position and wing contamination. Historically, stall warning systems have evolved from simple on/off designs to more sophisticated incremental feedback mechanisms, providing pilots with auditory and tactile cues as they approach stall conditions. Understanding the specifics of these systems is essential for effective flight safety management.
Boeing707
My question is how precise is the stall warning vane in detecting the stagnation point on the wing?
The lift transducer is an LVDT so electrically speaking it is a continuous signal. But when approaching a stall, could the vane be held in between center and full deflection for a few seconds? (The vane is spring loaded to center, not sure of the exact force required to move but feels very light to touch).
Or maybe a better question: If the airflow at the stagnation point is 0 (vane center), does the airflow around the stagnation point slowly increase (vane in between center and full deflection) or is it pretty much full speed (vane instantly deflects to full position)?
The aircraft is of the 707 variant.
Stall warning is a safety feature, thus it is designed to trigger before the wing actually reaches stall, so that the pilot has sufficient time to react.
If I remember correctly they usually start sounding 2-3 degrees before the critical angle. But the critical angle depends heavily on flap position and wing contamination. The former can be taken into account when designing the control circuitry/program for the stall warning system, but the letter can be an issue, thus some aircraft may start giving the stall warning around 5 degrees prior to the critical aoa. What are actual current offset values, for these systems, I don’t know.
Historically there have been quite a few different designs, some worked like on/off switches, others were incremental or continuous. As far as I know only the letter are in use today and they give the pilot an incremental feedback (sound and stick shaking) on how near stall they are.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
