Question about Volume of Solids
  • Thread starter Thread starter Gauss177
    Solids Volume
Gauss177
I'm having trouble with problems where you have to find the volume of a solids that are not solids of revolution. Can someone help me with these problems and also tell me a general way of approaching these problems? Thanks
A hole of radius r is bored through the center of a sphere of radius R > r. Find the volume of the remaining portion of the sphere.
2. Homework Statement
The base of S (the solid) is an elliptical region with boundary curve 9x^2 + 4y^2 = 36. Cross-sections perpendicular to the x-axis are isosceles right triangles with hypotenuse in the base.
For 1, that is a solid of revolution, try drawing it. For 2, it is very similar to integrating solid of revolution, only instead of adding up circles you are adding up triangles. Again, if you can picture the shape it shouldn't be too hard.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
