Work Done on a Suitcase by Various Forces
  • Thread starter Thread starter Crusaderking1
    Work
A luggage handler exerts a force of 155 N on a 16.7 kg suitcase up a 30-degree ramp, resulting in various work calculations. The work done by the applied force is calculated as 550 J, while the work done by friction is -179 J. The normal force and gravitational force do not contribute to work since their angles relative to the displacement are 90 degrees, resulting in zero work. The total work done on the suitcase is 371 J. The discussion concludes with a request for assistance in determining the suitcase's speed after traveling 4.10 m along the ramp.
Crusaderking1
*I already figured the problem out*
A luggage handler pulls a suitcase of mass 16.7 kg up a ramp inclined at an angle 30.0 degrees above the horizontal by a force \overline{F} of magnitude 155 N that acts parallel to the ramp. The coefficient of kinetic friction between the ramp and the incline is 0.267. The suitcase travels a distance 4.10 m along the ramp.
A. Calculate the work done on the suitcase by the force F.
B. Calculate the work done on the suitcase by the gravitational force.
C. Calculate the work done on the suitcase by the normal force.
D. Calculate the work done on the suitcase by the friction force.
E. Calculate the total work done on the suitcase.
F. If the speed of the suitcase is zero at the bottom of the ramp, what is its speed after it has traveled 4.10 m along the ramp?
F*s = Work
A. Is it:
work of F applied= (155 N)(4.10 m)cos30.0 = 550.0 J
B. Is it
work of friction=(43.7 N)(4.10 m)cos180.0 = -179.0 J
C and D. Wouldn't both be 0, considering cos90 = 0?
E. Is it just 550 J + 0 J + 0 J + -179 J = 371 J?
F. No idea, need help.
Thoughts? Thanks!
s is along the ramp right? So, why are you projecting things to the horizontal direction?
So work of f applied= 155 N(4.10 m)?
*I figured this problem out*
