Solving for Depth in Boyle's Law: Barometer Tube Submerged in Water
  • Thread starter Thread starter aamphys
    Boyle's law Law
The discussion revolves around calculating the depth of the top of a barometer tube submerged in water, given that the water rises 20 cm inside the tube. Using Boyle's Law, the pressure calculations lead to a pressure of 2.6 m of water at the top of the tube. To find the depth from the water surface to the top of the tube, the height of the water column inside the tube (0.8 m) is subtracted from this pressure measurement, resulting in a depth of 1.8 m. The confusion arises from interpreting the pressure as a height measurement rather than considering the physical distance from the water surface to the tube's top. Ultimately, the correct depth is determined by understanding the relationship between the pressures and the heights involved.
aamphys
An empty barometer tube,1m long is lowered vertically, mouth downwards, into a tank of water. what will be the depth of the top of the tube when the water has risen 20cm inside the tube?(atmospheric pressure may be assumed to be equal to 10.4m head of water)
boyle's states p1v1= p2v2 assuming temperature remains constant.
p1=10.4 m in m of water
v1= (1 x A) cubic meter
p2= (10.4 +h) in m of water
v2= (0.8 x A) cubic meter where a is area of cross section of tube.
substitute:
(10.4 +h) (0.8A)= 10.4 x 1 x A
10.4 +h = 10.4 divided by 0.8 = 13
and so the pressure due to the water coloum should be 13.10.4= 2.6
after this i can't get it right becase if the pressure is 2.6 then we should be able to use the formula pressure=ht x densityx g to find height of the water but the answer you get is not the answer in the book which says that the top of the tube is 1.8 m below the surface. It shows it as
2.6-0.8= 1.8
how exactly do you get 1.8 and why do you have to subtract 0.8 from 2.6 ?
Hi aamphys,
substitute:
2.6-0.8= 1.8
Because they want the distance from the water surface to the top of the tube. The distance from the water surface to the top of the water inside the tube is 2.6m, and the top of the tube is 0.8m above that, so 1.8m is the answer they are looking for.
isnt 2.6 suppose to be the pressure of the water column on the top of the tube ?
The fluid head is height already isn't it?
Hence with ψ = P/ρg
and P = ρgh
Haven't they already supplied you with the measurement that the surface between the air/water at the bottom of the tube is .8m from the top of the tube? And since the air/water interface is 2.6 m (of head) below the surface, that the top of the tube needs to be 2.6m - .8m?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
