Question on combining 2 streams of different pressure
  • Thread starter Thread starter sero2000
    Pressure
The discussion focuses on combining two fluid streams at different pressures—10 bar and 30 bar—while avoiding damage to the pump. A proposed solution involves using a tank to mix the streams before pumping them out as one, though this may not be cost-effective. Participants suggest employing a throttling process or throttling valve to manage the high-pressure stream, which would alter fluid velocity and pressure according to Bernoulli's equation. The conversation also touches on the use of Pressure Reducing Valves (PRVs) and the importance of maintaining a pressure below 10 bar at the mixing point to protect the low-pressure pump. Overall, the key is to ensure safe and efficient mixing of the streams without exceeding the lower pressure threshold.
sero2000
Well I was given an assignment to find ways to solve the the problem of how to mix the 2 streams in the digram together at the lowest cost possible.
The pressures of the 2 streams that are being mixed together are 10 bar and 30 bar
The fear is that instead of combining into 1 stream, the flow from the 30 bar will flow into the 10bar stream and damage the pump
[PLAIN]http://img94.imageshack.us/img94/1051/drawing1x.jpg
The only way i can think of so far is to just add in a tank at the intersection where the 2 streams meet to store both streams before i pump them out as 1 combined stream. But however i don't think it is very cost effective. So i stuck to as how i can continue.
What about using a throttling process on the high pressure line.
Also, think about relationship between pressure (and pressure drop) and fluid velocity, e.g., Bernoulli's equation.
Certainly the two streams would have to enter a chamber with a pressure less than 10 bar.
Hey thanks for the reply :D
Hmmm... By throttling process do u mean adding in a throttling valve? I am not sure if i gt it right but a throttling valve will change the velocity of the fluid and so based Bernoulli's equation the pressure would also change?.
Also while searching i also came across Pressure Reducing Valves PRV.
Is there a difference between the the throttling valves and the PRV?
If you are worried about the low pressure pump, just protect it with a check valve. As long as the pressure at the mixing point is less than 10 bar, you won't have a problem.
