Question on Equation Rearranging
  • Thread starter Thread starter nicole
The discussion revolves around rearranging the equation T^2 = kd + A/d for a physics lab exam. Participants clarify that plotting T^2d against d^2 allows for the extraction of the slope and y-intercept, which correspond to the constants k and A. It is emphasized that the relationship is linear when expressed in this manner, despite initial confusion about the non-linear nature of the original equation. The consensus is that using the linear form y = mx + b will facilitate finding the values of k and A. This method is confirmed as valid for the given graphing approach.
nicole
Hi everybody. Sorry for urgency, but I am in dire need of help for my physics lab exam. Has anyone ever had experience with the formula:
T^2 = kd + A/d
From a graph of T^2d (yaxis) vs. d^2 (xaxis), we can get the slope and the y intercept.
We are supposed to find the values of the constants k and A. Any ideas?
SO FAR...
we have the idea that from the graph we can get an equation of y=mx+b and use that to find the values of k and A. So, the b value would be (A/d) and the mx (kd). Does this work? Any ideas. THANK YOU SO MUCH IN ADVANCE
If this is T x T = kd + A/d with k,A constants and T, d variables it's a non linear equation, NOT a straight line.
Yes, but they were plottin (T^2 d) as a function of d^2. Now, THAT is then of course equal to T^2 d = k d^2 + A = m d^2 + b.
So the suggestion is obviously correct, but I wonder how the OP cannot see this him/her self...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
