Solving Exponent Laws: 2^3 / 2^0 - 2^-1 Question on Homework
In summary, the conversation discusses solving two different exponent problems using exponent laws. The first problem is solved by converting it to 2^3 /2^0 = 1/2^1, which simplifies to 8/2= 16. The second problem has no solution as the expression 3^g+3 - 3^g+2 is equal to 5. However, if brackets are used to indicate the exponent, the problem becomes solvable and the solution is y = 2.
Nelo
215
2^3 / 2^0 -2^-1
solving using exponent laws
i move the negetive one over and make it 2^3 /2^0 = 1/2^1
I get 8 on the left side, and 2 on the right, bring the 6 from the right to the left and get 2. The answer is 16, i don't know how to get it. Anyone?
2^3 / 2^0 -2^-1
Is that:
[tex]\frac{2^3}{2^{0}-2^{-1}}[/tex] ?
QuarkCharmer said:
2^3 / 2^0 -2^-1
Is that:
Yes because the answer is 16 :)
yes it isss
[tex]\frac{2^3}{2^0}- 2^{-1}= \frac{8}{1}- \frac{1}{2}= 8- \frac{1}{2}= \frac{15}{2}[/tex]
[tex]\frac{2^3}{2^0- 2^{-1}}= \frac{8}{1-\frac{1}{2}}= \frac{8}{\frac{1}{2}}= 16[/tex]
How do you solve this problem?
3^g+3 - 3^g+2 = 1458
Ive been stuck on it for a whole hour
There is no solution. You write 3^g+3 - 3^g+2, which means (3^g) + 3 - (3^g) + 2, and this is equal to 5. If you actually mean something different, USE BRACKETS. For example, maybe you mean 3^(g+3) - 3^(g+2) = 1458. Of course, that would have a solution, which we could get quite easily using the fact that 3^(g+3) = 3*3^(g+2).
RGV
Theres no brackets, and there is a solution , its 4.
Heres another one.
-500 = 5^y+1 -5^y+2
looks like the same type of problem, answer to this ones 3
You seem to be missing a VERY IMPORTANT point: you *must* use brackets because otherwise what you are writing is in violation of all standard math writing rules. People will automatically assume you mean what you write, but apparently that is not true!
RGV
Here's another one.
-500 = 5^y+1 - 5^y+2
If you mean that y+1 and y+2 are exponents, then you should (must, actually) use parentheses or other grouping symbols to indicate where the exponent ends and the rest of the expression picks up again.
I assume you meant:
-500 = 5^(y+1) - 5^(y+2) .
It works even better to use the X2 button above the advanced version of the reply box. Then you don't need the parentheses. This gives:
-500 = 5y+1 - 5y+2
To solve this, notice that 5y+2 = (5)(5y+1)
Factor (5y+1) out of 5y+1 - (5)(5y+1).
The answer is y = 2.
1. What are exponent laws?
Exponent laws are rules that govern how to simplify and solve mathematical expressions with exponents. They provide a systematic way to manipulate and simplify complex expressions involving exponents.
2. How do I solve an expression with exponents?
To solve an expression with exponents, you can use the exponent laws to simplify the expression. First, apply the law of exponents that states a^m x a^n = a^(m+n). Then, use the law that says a^m / a^n = a^(m-n). Finally, use the law that states (a^m)^n = a^(m*n). Remember to follow the rules of order of operations (PEMDAS) when solving the expression.
3. What is the rule for dividing exponents?
The rule for dividing exponents states that when dividing two terms with the same base, you can subtract the exponents. So, in the expression 2^3 / 2^0, you can simplify it to 2^(3-0) = 2^3 = 8.
4. How do I handle negative exponents?
Negative exponents can be handled by using the law that states a^-n = 1/a^n. This means that if there is a negative exponent in the expression, you can rewrite it as the reciprocal of the term raised to the positive exponent. For example, in the expression 2^-1, you can rewrite it as 1/2^1 = 1/2.
5. Can you provide an example of solving an expression with exponents?
Sure, let's solve the expression 2^3 / 2^0 - 2^-1. First, we apply the law of exponents to simplify the term 2^3 / 2^0 to 2^3 = 8. Then, we use the law for negative exponents to rewrite 2^-1 as 1/2^1 = 1/2. Finally, we have 8 - 1/2 = 15/2 as our final answer.
