Question on showing general formula of solution
RoboNerd
show that the general solution of the differential equation d^2/dt^2 + 2 *alpha * dr/dt + omega^2 * r = 0,
where alpha and w are constant and R is a function of time "t" is R = e^(-alpha * t) * [ C1*sin( sqrt(omega^2 - alpha^2) * t) + C2*cos( sqrt(omega^2 - alpha^2) * t)
IF alpha^2 - omega^2 < 0.I was struggling over how to solve this problem and I would be very grateful if someone have me a badly needed hint.
None come to mind as of now[/B]
I said let R = f(t) = e^(d * t).
I then had the expression when I plugged it into the differential equation
d^2 * e^(d * t) + 2 *alpha * d * e^(d * t) + omega^2 * e^(d * t) = 0
I canceled the e^(d * t) term and I got the characteristic equation:
d^2 + 2*alpha*d + omega^2 = 0
I then applied the quadratic formula to solve for d:
d = [ -2 *alpha +/- sqrt( (2*alpha)^2 - 4*omega^2 ) ] / 2.
I thus get d = -alpha +/- sqrt (alpha^2 - omega^2 )
Now I have a huge problem. If alpha^2 - omega^2 < 0, then my d is non-real and I can not proceed from here.
I tried substituting in the functions sin(d*t) and cos(d*t) instead of e^(d*t) into the differential equation and solving, but then I become stuck as I can not eliminate the plugged in functions at all from the general expression.
Could anyone please be kind enough to help?
Thanks, and have a great day!
The absolutely 100% standard method of showing something is a solution is to substitute it into the equation to see if it "works". you have an explicit formula for r(t), so nothing prevents you from taking the derivatives, etc.
Have you seen the identity
e^{ix} = \cos x + i \sin x before? It's very important to the theory of second-order linear constant coefficient ODEs. Now for real a and b the quantities e^{a + ib} and e^{a - ib} are complex conjugates, so it follows that the linearly independent combinations <br /> \frac12(e^{a + ib} + e^{a - ib}) and \frac1{2i}(e^{a + ib} - e^{a - ib}) are real, and you can easily establish that they are equal to e^{a}\cos b and e^a \sin b respectively.
eix=cosx+isinxeix=cos⁡x+isin⁡x​
e^{ix} = \cos x + i \sin x before? It's very important to the theory of second-order linear constant coefficient ODEs. Now for real aaa and bbb the quantities ea+ibea+ibe^{a + ib} and ea−ibea−ibe^{a - ib} are complex conjugates, so it follows that the linearly independent combinations
12(ea+ib+ea−ib)12(ea+ib+ea−ib)​
12i(ea+ib−ea−ib)12i(ea+ib−ea−ib)​
\frac1{2i}(e^{a + ib} - e^{a - ib}) are real, and you can easily establish that they are equal to eacosbeacos⁡be^{a}\cos b and easinbeasin⁡be^a \sin b respectively.
Hi. No, I have not seen this identity before. Thanks for drawing it to my attention.
I understand how one might be able to simplify the expression with the given identity, but I do not understand why one would after finding two complex conjugate expressions do the linear combinations
12i(ea+ib−ea−ib)​
which you say are equal to the final results
Could you please explain why you feel the need to take the linear combinations by adding/subtracting the two conjugate pairs and then dividing by 2 or 2i respectively?
What is the theory behind your actions? How does taking these linear combinations help?
Thanks so much for your help, and have a great day!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
