Question on the relationship between intensity of sound, amplitude and 1/r^2
The discussion revolves around the relationship between sound intensity, amplitude, and distance from a sound source, specifically in the context of a speaker emitting sound waves uniformly. The original poster presents a scenario involving the amplitude of sound at two different distances and expresses confusion regarding the changes in amplitude and intensity.
  • Participants explore the relationship between intensity and amplitude, questioning how amplitude can decrease with distance despite constant power from the source. There is also discussion about the appropriate units for measuring sound amplitude and intensity.
Some participants have provided insights that clarify the relationship between intensity and amplitude, noting that as distance increases, intensity decreases, which in turn affects amplitude. There is acknowledgment of the need to consider the total power of the source and how it relates to intensity at specific points.
Participants are navigating assumptions about the constancy of power and the implications of distance on sound intensity and amplitude. There is mention of potential confusion regarding the units used for measuring amplitude.
aznking1
Suppose sound wave is emitted uniformly in all directions by a speaker.
At a distance of 1.1m, the amplitude of it sound is 1.2x10^-8m
What is the amplitude of sound at a distance of 1.7m?
What I'm confused is why does the amplitude of sound change? Isn't intensity = Power/Area? So at a greater distance, it just means that intensity is lowered. But power from a source is always constant isn't that right? And since power is proportional to amplitude squared, why does the amplitude decrease? am i missing out something?
The answer is 7.8x10^-9 using the relationship of intensity proportional to amplitude^2 and 1/r^2 if you are curious.
Lower intensity at some specific point corresponds to a lower amplitude at that point. Meters as unit looks odd, I would expect Pa (pressure), but that should be irrelevant.
Constant in which way? I think you mean the total power here.
Ahh okay. I think i get it now after reading your post and thinking for so many hours.
Firstly, the formula intensity = power/area gives the power at a particular point. If we were to sum all the points ( surface area of a sphere), we would get the total power of the source, which is always constant
Hence, as distance increases, the intensity at a point decreases, meaning power at the specific point decreases, and so amplitude decreases, as you have mentioned.
Thank you! now i can get a good night's sleep haha... assuming i am correct
That is right.
Small issue: "Power at a specific point" is not meaningful. Intensity is. If you integrate that, you get a power.
10K
  • · Replies 23 ·
16K
