Question on Two Decays of Rho Meson
  • Thread starter Thread starter dingo_d
    Meson
dingo_d
I saw here, but since the thread is closed I need to ask my question in a new thread.
I have two decays: \rho^0\to \pi^+\pi^- and \rho^0\to \pi^0\pi^0. The text says that both are allowed with respect to laws of conservation of energy and impulse. Why is the second one forbidden?
Both rho meson and pi meson, are a triplet in isospin space, so I don't see a problem there. But how are both allowed with respect to conservation of impulse, if the impulse of rho is 1, and of pions is 0 (impulse as in J=L+S)?
Is it just because the Clebsch-Gordan coefficient in the second decay is 0 and in the first it's \frac{1}{\sqrt{2}}?
So the coupling of two pi0 is forrbidden in the isospin coupling? Is that the answer?
The final state is a two-particle state, so it is possible to have nonzero orbital angular momentum (##L\neq 0##). However, once you identify the possible orbital state, you must also consider the symmetry of the wavefunction under exchange of the ##\pi##s.
This is not an issue, since that coupling exists. In fact, ##\rho^0\to \pi^0\pi^0\gamma## is an allowed decay channel.
Thank you :)
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
