Question regarding non flow steam process
The discussion revolves around calculating the index n for a non-flow steam process in a steam engine cylinder, given specific pressures and dryness values during expansion. The user initially struggles to find the necessary values in the steam tables to compute the specific volume at the lower pressure of 0.28 MPa. A suggestion is made to obtain a better set of steam tables, as the current one does not provide the required data. The user expresses gratitude for the hint, indicating it was helpful. Overall, the thread emphasizes the importance of accurate steam tables for thermodynamic calculations.
kanzeon1
Hi There, quite an informative forum.Im struggling with a question which reads as follows:
At a certain point during the expansion cycle in a steam engine cylinder, the steam pressure was 1.1 MPa and the dryness 0.85, At the end of the expansion process the pressure was 0.28Mpa and the dryness 0.80, assume that the expansion obeys the law PV^n=C.
The value of the the n, index is asked. I am struggling to find it.
I used the steam table to get the values of vf and vg for a pressure of P1 1100kPa and used the formula v= xvg +(1-x)vf and get v= 0.15m^3/kg, I can't find the value 0.28Mpa=280kPa on the steam table and i can't get v2 which will allow me to calculate the index n by using P1V1^n=P2V2^n as the steam will be behaving like a ideal gas as i understand it?
Thanks in advance for the help.
Any tutorials with worked out examples on non flow steam processes that anybody can make available to me?
Thanks
Atmospheric pressure is 101.325 kPa. Your exhaust steam is 280 kPa. Get a better set of steam tables. Hint: Google is your friend.
Thanks for the hint, helped me a lot :)
