Questions About Air: Why Hot Air Rises & More
  • Thread starter Thread starter mindboggling
    Air
Warm air can hold more moisture than cold air due to its higher energy, which allows it to evaporate and sustain more water molecules. Strong winds can be cold because the speed of air movement does not necessarily correlate with its temperature; rather, the temperature reflects the average kinetic energy of air molecules. Hot air rises when the temperature at the bottom surface is higher than at the top, causing a decrease in density that allows buoyancy forces to act. The interaction between air particles and their velocities contributes to the temperature and wind speed dynamics, where temperature represents the random energy of particles and wind speed reflects their ordered motion. Understanding these concepts is essential for grasping air movement and thermal dynamics.
mindboggling
Why do warm air hold more moisture than cold air?
Is it because the volume of warm air is larger than cold air because warm air expands?
How can strong winds be cold, how do they work?
If the movement of air is fast, then wouldn't it heat the body of air up? Are strong winds a moving body of air with slow kinetic energy? Cant visualize how a wind can be strong and cold.
Why does hot air rise
it'll really help if you can explain to me as detailed as possible using concepts such as kinetic energy and whatever that is necessary
Thanks guys.
Thanks guys.
Case(1): Warm air has more energy associated with it than colder air; therefore, it can evaporate and susatin more water molecules than colder air. This is probably due to the weak hydrogen bonds obetween the water and air.
Case(2), as your speed increases, the thermal boundary layer decreases(This is the thickness from the vertical plate wall to the black line on the right hand side). When your boundary layer decreases, the heat transfer increases because it is a function of the Reynolds Number, and the Reynolds Number is a linear function of the velocity.
http://www.ami.ac.uk/courses/ami4817_dti/restricted/u04/images/Incropera-9.3.gif
Case (3): Hot air rises ONLY if the temperature of the BOTTOM surface is larger than the temperature of the top surface AND the density of the fluid decreases as you go down. If the density does not decrease as you go down (as would be the case with a hot upper surface and cold lower surface), gravity can not induce body forces to 'push' the heavier fluid down to replace the lighter fluid (which wants to rise).
The number used in that case is not the Reynolds number, but an analogous Grashof number. It is a ratio of the buoyancy forces to the viscous forces. SO, even though the temperature might be higher at the bottom surface than the top AND the density decreases as you go down, fluid motion will occur ONLY if there is enough buoyancy forces to overcome the viscous forces impeding the flow. In a sense, there is a minimum threshold you must overcome before you get natural circulation.
I think temperature is basically the "variance" in the velocity of the different air molecules, whilst the wind speed is the "average" velocity.
The particles of air at the surface of the body have zero velocity because of the no slip condition. This means that the heat is transferred through conduction only at the skin surface. As you move away from the skin surface, the velocity slowly increases until you are at the freestream velocity. During this transition, the particles of air interact with the particles next to it, picking up some energy as you move away from the body.
The velocity would be the ordered motion in the direction of the streamlines. The temperature would be the random energry in each particle of air, which could be in the form of translation, vibration, etc that is superimposed on the ordered motion of the velocity. I guess in a way, you could call it a 'variance', if you wanted to compare it to the case where the freestream temperature is exactly the same as the surface temperature. In that case the variance between the two would be the thermal component (I guess :confused:).
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
