Questions about Light: Will Cold Chamber Affect Beam?
  • Thread starter EEstudentNAU
  • Tags
    Light
In summary, passing light through a fresnel lens and another lens before a cold chamber will not necessarily result in a hot beam at the end, as the term "temperature" does not apply to empty space. The effects on the light will depend on the type of matter in the chamber, such as phosphors which can absorb and re-emit light. In order to calculate the energy of the photons, additional information such as the type of matter and its temperature is needed. One option to filter out invisible infrared radiation is to use a "heat mirror."
EEstudentNAU
30
If light passes through a fresnel lens and then through another lens focusing it a bit so it is not as concentrated (but still somewhat), and passes through a cold chamber, will the beam at the end still be hot, or will it be a bunch of low energy photons?
"Temperature" means nothing in empty space -- it's a number that describes the statistics of a bunch of particles considered together. If you pass the light through a "cold chamber," then you're passing the light through some kind of matter. That matter could do almost anything to it, and you haven't specified what kind of matter it is. Phosphors, for example, absorb high-energy photons and re-emit lower-energy photons.
- Warren
Carbon dioxide will be in the chamber. Is there a way to calculate the photons energy? Say the carbon dioxide is at -78º C. What other information do I need?
I wouldn't expect the CO2 temperature to have any useful effect on the heat of the beam unless you're expecting the increased density at cold temperatures will scatter the light more. The energy present in a beam of light radiation is the amount of photons times the energy per photon, which is inversely proportional to wavelength. Energy of a photon is h*c/lambda
I don't know what your application is, but you might look into a "heat mirror". These will reflect the invisible infrared radiation that comes off of many light sources, and pass only the visible stuff.
FAQ: Questions about Light: Will Cold Chamber Affect Beam?
1. How does temperature affect the beam of light?
Temperature can affect the beam of light in several ways. Firstly, it can alter the speed of light, causing it to travel slower or faster depending on the temperature. This can lead to changes in the wavelength and frequency of the light. Additionally, temperature can also affect the density of the air, which can cause refraction and distortion of the light beam.
2. Will a cold chamber affect the intensity of the light beam?
Yes, a cold chamber can affect the intensity of the light beam. As the temperature decreases, the molecules in the air become less active, which can cause the light to scatter and lose intensity. This effect is more pronounced in a cold chamber because of the lower temperatures and controlled environment.
3. Can cold temperatures affect the color of the light beam?
Yes, cold temperatures can affect the color of the light beam. As mentioned earlier, temperature can alter the wavelength of light, which can result in a change in color perception. For example, if the temperature decreases, the light may appear bluer, while warmer temperatures may make it appear more yellow or red.
4. How does a cold chamber affect the polarization of light?
A cold chamber can affect the polarization of light in several ways. Firstly, as the temperature decreases, the molecules in the air become less active, which can cause the light beam to scatter and lose its polarization. Additionally, changes in temperature can also affect the orientation of polarizing filters, which can alter the polarization of the light passing through them.
5. Is there a specific temperature at which the light beam will be affected the most?
Yes, there is a specific temperature at which the light beam will be affected the most. This temperature is known as the critical temperature, and it varies depending on the type of light and the materials involved. For most light sources, the critical temperature is typically below freezing, but for specialized light sources, it can be much lower.
