Questions about Light: Reflection & Spot Shape
  • Thread starter Thread starter Misr
    Light
Reflected images are more visible at night due to the absence of external light, allowing only the viewer's reflection to be seen. When blue light is placed in a glass cube, it produces a circular spot, while red light results in a rectangular spot, though the reasons for this difference are debated. The perception of left-to-right swapping in reflections is a result of human designation rather than an actual physical change, as reflections maintain the spatial relationships of objects. Each point in a reflection corresponds directly to its counterpart, without true swapping. Understanding these concepts clarifies common misconceptions about light and reflection.
Misr
1.it's easy to see your reflected image on the glass window of your room during night,while it's hard too see your image during day
2.when a blue light is placed in the centre of a glass cube,light comes out from the cube as circular spot, while when red light is placed in the cube,light comes out as a rectangular spot
could you explain the reasons??
Science news on Phys.org
For 1): What reaches your eye is the light coming from the outside showing the trees and the light reflected from the inside showing you. At night, the light from the trees outside is absent, leaving only your mirror image which is then more clearly visible.
I'm not convinced that 2) is a general effect.
But why is the reflection a left-to-right swapped image and not an up-and-down swapped image! ;)
It's not, that's just a fault of human designation of what "right" and "left" should be. Put an object up that has four unique points (up, down, left, right). Each point will be directly across from itself in the reflection. There is no swapping.
So your left hand is still across from your left hand in the mirror. The outer edge of your hand conforms to the outer edge of your hand's reflection, just like the outer edge of your head conforms to the outer edge of your head's reflection.
I'm not much into the guru cult that some people on the Internet seem to establish around physicists that are widely know, but incidentally I recently saw an amusing YouTube video of Richard Feynman talking about this:
Great answer,Thanks
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
