What are some common questions about Peskin's QFT book?
  • Thread starter Thread starter ismaili
    Peskin Qft
ismaili
Dear all,
While I was reading chap2 of Peskin, I got some questions.
(1) The vanishment of the commutator of fields [\phi(x),\phi(y)]=0 means that the measurements at x and y do not interfere at all. Is this a postulate? Is this the so-called micro-causality?
(2) How Peskin deform the contour of fig.2.3 ? Why the two contour integrals are the same?
(3) How to prove if x,y are space-like separated, there is a continuous Lorentz transformation take x-y to -(x-y)? i.e. I don't understand fig.2.4.
Thanks for anyone.
Yes, this is the microcausality condition.
If they are spacelike separated you can define a spacelike vector V that connects them. Then, you can easily show that there exists a Lorentz transformation that transforms V into -V. This will be a rotation of 180 degrees. If you try the same procedure for two points within the light-cone, connected by a timelike vector, you will see that the transformation is not possible.
Thanks. I guessed this is a "postulate", however, the book didn't give a clear assertion that this is a postulate. So I doubt that this can be derived. Now I think it is a postulate of QFT.
Thanks, I got it. But it seems that the argument have to be slightly modified. If V is a spacelike vector, we need not only the rotation to transform V into -V. Because the temporal coordinate is flipped too, so I guess we need a boost also.
Thanks for the discussion!
I started a thread a time ago with a similar question. You may want to use the search function to find it. It seems it is actually a postulate: it can be derived for specific representations such as the Fock representation that, however, restricts itself to positive mass solutions. There is no general way to derive it.
Yes, but I think that a boost will not do the work to completely transform V into -V if it is timelike.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
