Questions Regarding the Phase Diagram
The discussion revolves around understanding the phase diagram, specifically how different processes relate to it, including the effects of pressure and temperature on phase transitions of water. Participants explore theoretical scenarios involving piston-cylinder assemblies, cooling of water, and the implications of air pressure on phase changes.
  • Some participants propose that cooling water in a piston-cylinder assembly at constant pressure results in a single phase throughout the process.
  • Others argue that cooling water exposed to saturated air follows the saturation line until the triple point, questioning the effect of total air pressure.
  • A later reply questions the implications of unsaturated vapor pressure and its effect on thermodynamic equilibrium.
  • Participants discuss the formal definition of pressure in phase diagrams, with some suggesting it is the force per unit area, while others seek clarification on its meaning in multiphase systems.
  • One participant inquires about the necessary increase in air pressure to affect the freezing point of water, exploring the relationship between pressure and phase changes.
  • There is a discussion on the Poynting correction and its application to determine changes in chemical potential and free energy in liquid and vapor phases.
  • Some participants express confusion regarding the connection between pressure changes and melting temperature, particularly in relation to real gas effects.
Participants express a mix of agreement and disagreement on various points, particularly regarding the effects of pressure and temperature on phase transitions. There is no consensus on the implications of air pressure changes or the relationship between pressure and melting temperature.
Limitations include unresolved assumptions about the behavior of vapor pressure in non-equilibrium conditions and the dependence on specific definitions of pressure in different contexts.
This discussion may be useful for individuals interested in thermodynamics, phase transitions, and the behavior of substances under varying pressure and temperature conditions.
Red_CCF
Hello
I’m wondering if my understanding of how different processes relate to the phase diagram here is correct.
1) If a piston cylinder assembly maintains a constant 1atm pressure on some water and the water is cooled, we would be going horizontally along the red line from 373.15K to 273.15K at 1atm and the system will only have one phase at any point in the process?
2) If I have a cup of water exposed to air, assuming the air is saturated at all times, cooling the water from say 373.15K means we are following the saturation (black) line separating liquid-vapor until the triple point? What effect does total air pressure play in this?
3) For 2), what if the vapour pressure is not saturated (some sort of venting carrying it away)?
4) Is there a formal definition for what pressure in the phase diagram is? For a single phase closed system I see it as the pressure held by the container, but what about for a multiphase system?
Thank you very much
Science news on Phys.org
Red_CCF said:
Hello
Yes, liquid.
Not much.
In this case, the system won't be at thermodynamic equilibrium. However, the interface will be very close to thermodynamic equilibirum, and the partial pressure of water vapor in the air at the interface will be equal to the equilibrium vapor pressure at the liquid temperature at the interface.
Force per unit area?
Thank you very much
Again, force per unit area.
Chet
Chestermiller said:
Not much.
What if the air pressure is exaggerated to the order of 100MPa? What I'm trying to get at is, on what order of magnitude does the air pressure have to increase to get to the freezing point in Case 1 (1atm constant applied pressure) or about a 0.01C decrease?
Had this scenario occurred and I continue to cool past the triple point, do I simply end up with solid and saturated vapour at the solid-vapour interface and the solid will sublimate until it disappears (air or no air wouldn't change a thing)?
Chet
For an adiabatic closed box with solid/liquid and saturated vapour, we always use the vapour pressure as the pressure of the system for calculations. Neglecting gravitational effects, is the vapour pressure equal and evenly distributed within the liquid/solid it is in equilibrium with (my feeling is that it is)?
Thank you very much
Do you know how to determine the change in partial molar free energy (chemical potential) of a component in a gas mixture and the change in free energy of a liquid with changes in pressure and temperature?
Yes.
Yes, aside from statistical mechanical fluctuations.
Chet
For an ideal gas mixture, this is what I found (I couldn't figure out how to do equations in this new format):
u_i = g_i + RTln(y_i*p/p_ref)
Taking the derivative with respect to T and p while holding one of them constant should give the change in chemical potential with respect to each variable. I'm not sure how to determine changes for liquid, is there some sort of table for this?
Thank you
For the liquid, you start with the free energy at the equilibrium vapor pressure of the liquid and temperature T, and you then integrate vdP from the equilibrium vapor pressure to the actual total pressure. This is called the Poynting correction. You then set the chemical potential (or fugacity) of the water in the liquid equal to the chemical potential (or fugacity) of the water vapor in the gas phase. To do high total pressures, of course, you also need to get the pressure correction for the fugacity of the water vapor in the gas.
Here is a nice link on how to do the whole thing in detail: http://web.mit.edu/10.213/www/handouts/vle.pdf
Chet
Chet
Hi Chet
Apologies, it look me a little while to look at this.
I'm confused about how the above method can be used to predict the melting temperature change. Assuming that my mixture of liquid and vapour is already at equilibrium at some total pressure (vapour is saturated), if I increase the total pressure without changing temperature, I see changes in the fugacity coefficient, activity coefficient, and Poynting Correction Factor (total pressure term) in the last equation but I can't draw the connection between that and phase change.
Am I correct to say that the effect on melting temperature in this case is a result of real gas effects only (due to the use of fugacity) and theoretically, if these effects did not exist (at any total pressure), melting point is independent of total pressure?
I am also wondering why the total pressure change must be several orders of magnitude higher to achieve the same melting point as that by a much smaller applied pressure (Case 1, horizontal red line of constant applied pressure of 1atm in the diagram in my OP), as the difference is essentially the presence of vapour phase.
Thank you very much
I assume you are comfortable with the idea that, at melting equilibrium, the free energy per unit mass of liquid must equal the free energy per unit mass of the solid. So if the temperature changes, the pressure has to change in such a way that the difference in free energy between the liquid and solid must remain zero. Otherwise, all the solid will melt to form liquid, or vice versa. So, starting out from melting equilibrium at a specific melting temperature and pressure, the changes in free energy of the solid and liquid are:
[tex]dg_s=-s_sdT+v_sdP[/tex]
[tex]dg_l=-s_ldT+v_ldP[/tex]
So,
[tex]d(g_l-dg_s)=-(s_l-s_s)dT+(v_l-v_s)dP=0[/tex]
This means that, in order to maintain melting equilibrium,
[tex]\frac{dP}{dT}=\frac{(s_l-s_s)}{(v_l-v_s)}[/tex]
But, we also know that
[tex](s_l-s_s)=\frac{h_l-h_s}{T}[/tex]
where ##h_l-h_s## is the heat of fusion. If we substitute, we then get
[tex]\frac{dP}{dT}=\frac{(h_l-h_s)}{T(v_l-v_s)}[/tex]
Now, we know that the specific volumes of the liquid and solid are very small, and the difference is ultra small. So the denominator on the right hand side is going to be very small, and dP/dT is going to be very large.
Chet
So,
Chet
Is the P used here the vapour pressure or the total pressure?
Thank you
Thank you
This is a single component system, so the only place where you can have 3 phases present at equilibrium is at the triple point. Check this out using the phase rule: if the number of phases is 3 and the number of components is 1, there are zero degrees of freedom. This is also shown on your phase diagram. So, if you have solid and liquid present at equilibrium, there must be no vapor present (except at the triple point). So, in this equation P is the total pressure.
If you have three phases present in a closed container and set the temperature to any value other than the triple point temperature, when the system equilibrates at that temperature, there will be only one or two phases remaining.
Chet
Chet
So in the above derivation we are essentially looking at something like a closed piston-cylinder assembly where we can apply pressure differently?
How does the analysis change if we have a closed, fixed volume container with a cup of water inside, and total pressure is varied by changing the air pressure?
Thank you
Thank you
Let me restate your question in a more precise way. You have W kg of water and A kg of air in a cylinder (no need for the cup) initially in equilibrium at a pressure of 1 atm pressure and 20 C. You can control the pressure in the cylinder using a piston and you can control the temperature in the cylinder using a constant temperature bath. You change the pressure to P and the temperature to T. What is the nature of the contents of the container when the system re-equilibrates? That is, how is the W kg of water distributed between ice, liquid water, and water vapor?
Is this a satisfactory statement of what you wish to analyze? (No need to hold the volume constant. You can answer what you want more easily by solving the problem as I have stated it.)
Chet
Chet
That is essentially what I'm looking for. However, in this setup, we cannot independently control the vapour pressure since the piston will raise the partial pressure of the vapour by the same proportion as the air pressure. Is there another possible setup where air pressure and vapour pressure are controlled independently (or a better question may be, does this even matter)?
Thank you
This won't happen unless there is no liquid or solid present.
Thank you
It doesn't matter. So let's get started.
We are going to assume that the air is insoluable in liquid water and ice. As an initial state, the temperature is going to be 20 C, the pressure is going to be 1 atm, and the piston is situated so that the volume of material in the cylinder is 1 liter. The bottom half of the cylinder is filled with liquid water, and the top half of the cylinder is filled with a mixture of air and water vapor, with water vapor at its equilibrium vapor pressure at 20 C. Determine:
  • the mass of liquid water in the bottom half
  • the partial pressure of water vapor in the top half
  • the partial pressure of air in the top half
  • the mass of water vapor in the top half
  • the total mass of water in the cylinder
  • the total mass of air in the cylinder
We are going to change the temperature and/or the pressure to new values. I want you to specify what these new values should be. I suggest that you begin by choosing conditions that are easy to get answers for, so that we can get some experience. Then, we can start to move to more complicated combinations of temperature and pressure. So please, specify the first combination of pressure and temperature that you want to move to.
Chet
Chet
  • the mass of liquid water in the bottom half: 0.499kg (assuming it is 50% by volume)
  • the partial pressure of water vapor in the top half: 2.339 kPa
  • the partial pressure of air in the top half: 98.96 kPa (assuming 1atm = 101.3kPa)
  • the mass of water vapor in the top half: 8.65mg
  • the total mass of water in the cylinder: 0.499kg (neglecting mass of vapour)
  • the total mass of air in the cylinder: 0.588g
I think a easy new condition would be 0C, 1atm (same pressure).
Thank you
Thank you
Nice job.
OK. Now 0 C is slightly below the triple point of water, 0.01 C, so you will have no liquid water in the container. Let's see what you can do with this case. Please do the calculation for the same amounts of water and air in the container, and, of course, also determine the new volume. What is the specific volume of ice under these conditions?
Chet
Chestermiller said:
Nice job.
Chet
Actually I will do 0.01C (right at the triple point) since that's the lowest temperature my book's steam table goes to. I'm going to assume that we only have liquid and vapour here (I don't have the properties for solid but I think density at least is close to the liquid)
The new vapour/air volume is: V = mRT/P = 0.000588*0.287*273.25/100.64 = 0.458L
  • the mass of liquid water in the bottom half: 0.499kg (negligble amount of vapour condensed)
  • the partial pressure of water vapor in the top half: 0.661 kPa
  • the partial pressure of air in the top half: 100.64 kPa (assuming piston moves to maintain 1atm)
  • the mass of water vapor in the top half: 2.22mg
OK. What temperature and pressure do you want to try next?
I was thinking 90C
The new vapour/air volume is: V = mRT/P = 0.000588*0.287*363.15/31.36 = 1.95L
  • the partial pressure of water vapor in the top half: 70.14kPa
  • the partial pressure of air in the top half: 31.16kPa
  • the mass of water vapor in the top half: 0.826g
Actually, the mass of liquid water in the cylinder would now be only 0.498 kg. What do you want to try next?
Chet
Red_CCF said:
I was thinking 90C
I think now I will vary the pressure to say 10atm (i think we are still in the ideal gas range?) at 90C. New volume is 0.065L
  • the partial pressure of air in the top half: 942.86kPa
  • the mass of water vapor in the top half: 27.5mg
Okay. What next?
Chestermiller said:
Okay. What next?
I think I will increase pressure to 50atm:
  • the partial pressure of air in the top half: 4994.86kPa
  • the mass of water vapor in the top half: 5.2mg
I'm thinking about increasing the pressure again, at what point does the ideal gas assumption not hold? Is it possible to lower the triple point to 0C via increasing the pressure?
50 atm is already beyond ideal gas assumption accuracy.
In order for ice and liquid water to be in equilibrium, the fugacity of the ice must be equal to the fugacity of the liquid water. Since we are assuming that no air dissolves in either the liquid water or the ice, the fugacity of each must be the same as for pure ice and pure liquid water at temperature T and pressure P. Therefore, under our assumption, the only T-P path under which they can be in equilibrium is the path on the pure water phase diagram at the ice/liquid water boundary. Is there a pressure at which the fugacity of ice is equal to the fugacity of liquid water at 0 C?
Chet
Chet
In the above examples I assumed that air was an ideal gas and that changing the air pressure did not affect the phase equilibrium (if our volume was constant adding air wouldn't have changed anything). Base on the link you recommended, when real gas effects are considered, increasing the total pressure would increase the Poynting correction factor; I'm not sure how this affects the activity and fugacity coefficients but I read that increasing total pressure lowers the melting temperature, which implies that at 0.01C, with sufficiently high total pressure, the fugacity of liquid-solid (that otherwise would be equal) now shifts such that the liquid has a lower fugacity coefficient than of solid. Is this correct?
For ideal gases, I'm wondering why the assumption made in the previous examples are true. Physically, why does adding say 1atm of ideal gas not affect the equilibrium, since the liquid is being pounded with a much higher force than when it was at equilibrium with its vapour whose saturation pressure is a fraction of the total pressure?
Thank you
Let's do the case of having the system at 1 atm. total pressure at 0.01C with and without air present in the head space.
Without air present in the head space, we are dealing with the exact situation shown in your phase diagram. There is no vapor phase, and only ice and liquid water are present at equilibrium. There can be no head space. For the pure water situation, the only point at which you can have all 3 phases present at equilibrium is at the triple point.
Now for the case in which air is present in the head space. If the air cannot dissolve in the liquid and ice (our assumption), then as far as the liquid water and ice are concerned, it is the same as if there were no gas phase present. They don't know what is causing the total pressure to be 1 atm. However, a head space can now exist, and the gas phase can now have water vapor in it. Let's temporarily treat the gas phase as an ideal gas. What is the equilibrium vapor pressure of water at 0.01C? This will be the partial pressure of the water vapor in the gas phase when air is present and the total pressure is 1 atm. From this you can calculate the partial pressure of the air in the gas phase, and the mole fractions of air and water vapor in the gas phase. What values do you get?
Introducing the air into the container has given you one more degree of freedom for your system. There is now not just one combination of temperature and pressure in which you can have all three phases present at equilibrium (i.e., the triple point). You now have the ability to vary the temperature and pressure (along the liquid/ice equilibrium line) and still have all 3 phases present.
Including non-ideal gas effects at higher pressures is do-able, but is, of course, more complicated. Going to much higher pressures does not affect the liquid and solid phases (assuming air does not dissolve), but does affect how we handle the gas phase and the equilibrium calculation.
Questions?? Where do you want to go from here?
Chet
I can't get my head around why ideal gas has no effect on equilibrium state or in a sense, hold the water down. The pressure on the liquid (and in the head space) applied by the air at 1atm has a drastically different effect than 1atm applied by a piston even though the pressure felt by the liquid surface is the same.
For water at 0.01C the partial vapor pressure is 0.611kPa so the partial pressure of air is 100.6kPa. Mole fractions are 0.00603 and 0.993 for water and air respectively.
Chet
So adding air will essentially change the phase diagram, as opposed to just shifting it, such that for different air pressure we have a different phase diagram? I'm basically wondering, if we have a closed box at the triple point (0.01C), how would one find out how much air to add into melt the water (essentially shifting the melting point downwards).
Thank you
This is quite a bold statement. What makes you feel this way? How does the ice/liquid water mixture know what is causing the pressure on its surface?
Yes. that's about it. Problem solved.
For the ice/liquid water mixture, varying the pressure just moves you to a different point on the phase diagram. The pressure-temperature relationship for the ice/liquid water mixture does not change (assuming negligible air dissolves). But, if you don't vary the temperature and pressure along the pure water equilibrium line so that the temperature corresponds to the new total pressure, one of the phases will disappear.
Do you want to solve this specific problem? Tell me what specific combination of temperature and air partial pressure you want to look at?
Chet
I phrased that poorly, it was meant as a question not a statement. I'm was thinking, from the liquid's perspective, if I have air at 1atm, or a piston applying a pressure at 1atm, the liquid "feels" the same force, but the equilibrium state is very different. I get that the liquid has no idea what's causing the force and that the air cannot hold the liquid down like the piston can, but how come the same force has two different effects on equilibrium and cause the liquid itself to be at two different states despite being under the same pressure and at the same temperature?
Chestermiller said:
Yes. that's about it. Problem solved.For the ice/liquid water mixture, varying the pressure just moves you to a different point on the phase diagram. The pressure-temperature relationship for the ice/liquid water mixture does not change (assuming negligible air dissolves). But, if you don't vary the temperature and pressure along the pure water equilibrium line so that the temperature corresponds to the new total pressure, one of the phases will disappear.
Chet
I'm not too sure if there is a relatively simple way to do this, but if I start at the triple point equilibrium in a fixed volume container (no air), is there a way to see how changing the total pressure (maybe going from air partial pressure = 0 to some quantity like 50atm) "shifts" the equilibrium position on the phase diagram; I just want to get a qualitative feel about how pressure affects equilibrium position?
Thank you
The water and the ice have the same state whether the piston is pushing down or whether the air is pushing down. The only difference is that some of the ice and liquid water can evaporate into the gas phase at the equilibrium vapor pressure of liquid water and ice at 0 C and 1 atm. if air is present. You already showed that with your calculation.
Yes. The first step is to determine what the equilibrium temperature of a mixture of water and ice is (no air present) at a total pressure of 50 atm. Do you know how to do that?
Chet
10K
11K
