name123 said:
with the supposition that the speed of light isn't invariant, a meter ruler would be a different length according to Team A members than Team B members
You have to be careful in specifying exactly what is meant by "the speed of light isn't invariant". What appears as "the speed of light" in the table of SI units is just a defined number, 299,792,458; but if you go out and measure some light and how it is moving, you will be using a ruler that is some number of atoms long (and to be perfectly precise, you would have to specify exactly what kind of atoms), and measuring with a clock whose "ticks", if you are using the SI definition of the second, are determined by the frequency of a particular energy level transition in a particular kind of atom. So if Team A and Team B want to compare their measurements, they have to compare how many atoms long their rulers are (and make sure both rulers are made of the same kind of atoms), and exactly what kind of atom and which energy level transition they are using to define their clock ticks.
What "the speed of light isn't invariant" would mean is that, after both teams have verified that their rulers are
exactly the same number of the same kind of atoms long, and that their clocks are using
exactly the same energy level transition in the same kind of atom for their tick rate, they get
different results for the ratio of (ruler lengths traveled by light) / (clock ticks). The reason SI units now define the speed of light as a particular number is that, whenever such experiments have actually been done, Teams A, B, C, D, ... W, X, Y, Z have all gotten
the same number, 299,792,458, for the ratio of (ruler lengths traveled by light) / (clock ticks).
All of the SR stuff about length contraction, time dilation, etc., applies to rulers and clocks defined in this way: i.e., if we have a ruler that is ##L## atoms long, moving relative to us, then a ruler at rest relative to us will have the same length as the moving ruler (i.e., the ends will line up at a particular instant of our time) if it is only ##L / \gamma## atoms long. And if we have a clock moving relative to us, it will tick ##T## ticks (defined by the appropriate atomic energy level transition) in the same time as an identical clock at rest relative to us will tick ##T \gamma## ticks (defined by the same energy level transition).
name123 said:
It seems to me that using a meter as a measurement of distance relies on the assumption that clocks don't slow with motion
No, it only relies on the assumption that the clock and the ruler are at rest relative to each other and to the experimenter. That is the condition that ensures that you get the ratio 299,792,458 for the ratio of (ruler lengths traveled by light) / (clock ticks) (where the ruler is a particular number of atoms long and the clock ticks are determined by a particular atomic energy level transition). The fact that identical rulers and clocks in motion relative to the experimenter (and to his rulers and clocks) appear shorter and tick slower is not an assumption; it's an experimental fact.
