Quick error propagation problem
To propagate the error for the x-component of a velocity vector, the uncertainty in the angle must be converted from degrees to radians, as the derivative relationship used is valid only in radians. The calculations show that the uncertainty in the x-component results in a significant value compared to the answer. The method of using partial derivatives is appropriate, but the conversion is crucial for accuracy. The final uncertainty calculation yields a result of 0.02, which raises concerns about its magnitude relative to the computed value. Proper error propagation requires careful attention to unit conversions to ensure valid results.
mjolnir80
we are trying to find the x -component of a velocity vector (V*cos\theta)
our uncertainty for the velocity is +-.0003 and for the and it is .5(in degrees)
how do we propagate the error for this
v=.048 while \theta =27 degrees
using partial derivatives :
(vSin\theta).5 (degrees)+ (cos\theta).0003=
(0.048*sin27)0.5+(cos27).0003=0.02
the problem is this is a really big uncertainti compared to the answer and i was just wondering whether i did this right?
The method looks fine except that you need to convert your error to radians, as the relation \frac{d}{d \theta} \cos \theta=- \sin \theta is only true when \theta is in radians.
thanks allot!:smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
