Understanding Torque: Is it a Constraint for Motor and Generator Systems?
  • Thread starter Thread starter seang
In a motor-generator system connected by a rigid shaft, the motor must supply the exact torque required by the generator, assuming negligible losses. If the generator requires a torque of x, the motor must provide x or negative x to maintain balance. The torque is influenced by the radius of the wheels; a smaller wheel will have less torque due to its radius. The discussion touches on practical aspects like alignment and the need for flexible couplings in real-world applications. Overall, understanding torque is crucial for ensuring proper functionality in motor and generator systems.
seang
I don't often deal with torque, but I'm dealing with a question that's a bit out of my league, so here goes.
Consider a system where a motor is connected to a generator via a shaft. The generator has been found to require a certain torque. Assuming the shaft is rigid, the motor must supply the exact amount of torque which exists in the generator, right? regardless of other properties of the motor/generator.
In other words, in terms of homework problems, is this a constraint I can use? If I find that the torque at the generator is x, can I say that the motor must supply x? (or maybe negative x)
Yes, assuming losses are negligible. If the motor supplies more torque the output from the generator increases above intended and if less then the generator output falls below.
Suppose the generator has a big wheel, to the circumference of which is attached the shaft, the other end of the shaft being attached to a point on the circumference of the motor wheel, which is smaller in radius. (Have you guys seen an old steam locomotive?) I think this is basically the question asked?
Grossly speaking, the force in the shaft is same at both ends, and so the torque will be lesser in the smaller wheel, because the radius is smaller. The exact calculation will involve a lot of other things -- the shaft angle will change, and the shaft has to have a hinge to compensate for the changing distance between the points of attachments etc.
Hi Shooting Star :-)
You are describing a crank and connecting rod arrangement but I don't think the question requires it -- the motor and generator could share a common axle shaft (leaving aside practical considerations of alignment etc. requiring a flexible coupling).
Oh, so you mean just like an axle being rotated at one end. If the cross-section is same, then the torque will be the same.
thanks guys
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
