Quick Question - Moments about a force
  • Thread starter Thread starter jmcmillian
    Force Moments
To find the resultant force about point P, vectorially add the forces F1 and F2 using their position vectors from P. The moment of the resultant force about point P is calculated by summing the individual moments of each force about that point. This scenario resembles a force-couple system, where the transport couple theorem can simplify the analysis. The distance "r" used in the moment calculation should be the perpendicular distance from point P to the line of action of the resultant force. Understanding these concepts will clarify the calculation of moments in this context.
jmcmillian
Hi there, quick conceptual question just to make sure I know what I am doing...
I am given two forces, F1 and F2, in vector form with given magnitudes.
(I) Find the resultant force about point P (given).
(II) I am also asked to find the Moments of the resultant force about point P.
(I) I establish position vectors from P to each point (I'll call it A for F1 and B for F2) and multiply by magnitudes. Then add to get the resultant force about P.
(II) Then for the second part, I cross my resultant force about P with the "r" for the resultant force, which would be the distance between F1 and F2 from P?
It's that last sentence where you can see I'm unclear at. Any help would be greatly appreciated!
Hello!,
The resultant force about any point will be calculated by vectorial addition of all the forces. The moment of the resultant force about a point will be equal to the sum of the moments by each force about the same point.
This exercise sounds like a force-couple system, where you use the transport couple theorem in order to move all the force about the point P, and reduce the previous system to a equivalent one with one resultant and one couple.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
