Quick question on integration by parts
t_n_p
I'm following an example in the textbook that states:
http://img24.imageshack.us/img24/1672/33686252.jpg
I was just wondering what happened to the 2 out the front, I would have been more inclined to think this would be the next step:
http://img34.imageshack.us/img34/4854/a1aa.jpg
Any explanations?
when you perform the integration by parts you get the original integral on both sides of the equation, which leads to the cancelling of the factor of 2 on the right hand side
I'm not following 100%.
The integral on the RHS is not the original integral on the LHS?
This it the formula I used (and I am familar with):
(of course with respect to t here not x)
fyi: I let f = Gsintcost and g' = Gdot
everything works out fine, its just the 2 that has me puzzled
ok so in some bastardised short hand
du = G'
u = G
v = Gsc
dv = G'sc + G(c2 - s2)
\int du.v = uv| - \int u.dv
\int G'.Gsc = G.Gsc| - \int G.(G'sc + G(c^2-s^2))
\int G'.Gsc = G^2 sc| - \int G.G'sc -\int G^2(c^2-s^2)
2 \int G'.Gsc = G^2 sc| - \int G^2(c^2-s^2)
2 \int G'.Gsc = G^2 sc| + \int G^2(s^2-c^2)
I think dv should be dv = G'sc + G(c^2 - s^2)
yeah i think you're right, but hopefully the bit about the orginal intergal aappearing on the RHS is celar
bugger, I think dv = G'sc + G(c^2 - s^2), but then if I change that, then I don't get the correct answer!
I understand what you mean by the original integral showing up on the RHS (cos now I can take it over to the lhs and get 2* original integral).
edit: found the mistake. When I broke up the integral I forgot to take the minus inside both.
got it all sorted now.
Cheers!
no worries - i updated the working above as well
