Quick Question on mass/spring system
  • Thread starter Thread starter NBAJam100
    System
The discussion revolves around calculating the total energy of a mass-spring system, where a 3 kg mass oscillates with a given amplitude and period. The spring constant was determined to be 29.6 N/m, leading to a total energy calculation of 0.333 J using the formula (.5)kA^2. Additionally, there is a query regarding the direction of a periodic wave described by the equation .15m*sin(10t+(pi)x), with the conclusion that the wave moves in a positive direction due to the positive coefficient of x. The participant seeks clarification on these concepts, confirming their understanding of both the energy calculation and wave direction.
NBAJam100
A 3Kg mass, attached to spring oscillates w/ amplitude of .15m and a period of 2s. At time t= 0.5s the objects position is .019m.
Find the total energy of the system
(.5)mv^2+(.5)kx^2= (.5)kA^2
I found the spring constant to be 29.6 N/m... my only question is this... (.5)mv^2+(.5)kx^2
would give me the answer, as would (.5)kA^2 correct? to get the total energy i just did (.5)(29.6)(.15)^2 = .333J
Is that correct?
Yes it is.
rock.freak667 said:
Yes it is.
Thank a bunch rock... i also had one other quick question that i figure ill post here so i don't start another post minutes after this one...
A periodic wave has the equation .15m*sin(10t+(pi)x)
Now i am getting a little bit mixed up about how to determine the direction of the wave... I am going to say this wave is moving in a positive direction because (pi)x is positive... meaning it is going forward... is that correct? So when i rewrite the equation it would be .15m*sin(10t+(pi)(x-vt)) to account for the positive change? Thanks for all of the help guys.
