Quick question on Newton, gravity and planetary movement
The discussion centers on demonstrating the relationship between gravitational force and radius squared, specifically that |F_gravity| is inversely proportional to r^2. The acceleration of a particle in an elliptical orbit is also radial, leading to the equation a_r = -C/r, where C is a universal constant. The negative sign in the acceleration equation indicates that the force acts towards the center, reducing the distance r over time. Clarification is provided that the constants in the equations can differ, but their existence is sufficient for equivalence. The conversation concludes with an understanding of how gravitational forces, such as that between the Earth and the Sun, are inherently attractive.
Contadoren11
Hi,
I've been tasked with showing that the length of vector F_gravity is inversely proportional with radius squared (i.e. |F_vector|=c/r^2) and is central, i.e. consistently directed toward the same point. Apparently, this is the same as (<=>) the acceleration of a particle following an elliptical path being radial (and thus, directed towards the same point as F) *and* it being equal to
a_r = - C/r (1)
C ends up being 4*π^2*(a^3/T^2), i.e. positive.
My questions are: Why is there a minus in (1), and what is the explanation for the <=> being valid? I realize it's Newtons 2nd law, but the constants C and c could conceivably differ by more than m, no?
Apologies for the shoddy notions, not used to doing physics in english (or writing formulas outside of Word...)
|F_vector|=k*1/r^2 and central
a_r = - C*1/r (1)
where C is a universal constant. C ends up being 4*π^2*(a^3/T^2), i.e. positive.
Can't figure it out.
The minus sign is because the acceleration is towards the origin, the point r is measured from, so tends to reduce r.
I don't see that it matters that the constants can be different. You are only asked to show that there exist constants that make the two equivalent.
Gah, I messed up - forgot to put r^2 rather than just r in the formula for a_r.
Yes, I didn't check that since your questions didn't depend on that detail. Are you ok with this now?
Hm. So the force exerted on the Earth by the Sun would be considered negative as well, or? (Also, I don't understand what you mean by "so tends to reduce r").
I reckon I get the constants thing.
r is the distance from the Sun to the Earth, so is positive. ##\dot r## is the rate of increase of r, so is speed measured away from the Sun. The acceleration is the rate of increase of velocity away from the Sun, but it will be towards the Sun in practice, so its value will be negative. That is, over time, it acts to reduce the velocity (as a signed quantity) and hence to reduce r; in short, gravity attracts.
Of course! Thanks a lot for the elaboration.
