CD01
- 1
hey, so I just need to know the steps on how to slove for x in this equation
> 2.34=15.3*0.886^x
thanks.
> 2.34=15.3*0.886^x
thanks.
The power equation is a mathematical formula that represents the relationship between a base number and its exponent. It is written as a^b, where a is the base number and b is the exponent. The equation is solved by raising the base number to the power of the exponent. For example, 2^3 would be solved as 2*2*2, which equals 8.
To solve for x in the power equation, you need to isolate the variable on one side of the equation. In this case, you would need to isolate the exponent, which is represented by x. You can do this by taking the logarithm of both sides of the equation. The specific logarithm you use will depend on the base number in the equation.
To use logarithms to solve for x, you first need to identify the base number of the logarithm. In this equation, the base number is 0.886. Then, take the logarithm of both sides of the equation using that base number. This will give you an equation in the form of log(base number)(2.34) = x. You can then use a calculator to solve for x.
The exponent in the power equation represents the number of times the base number is multiplied by itself. It is used to express very large or very small numbers in a more concise form. For example, instead of writing out 2*2*2*2*2, we can use the power equation 2^5 to represent the same value.
You can check your work by plugging the value you solved for x back into the original equation. If the equation holds true, then your answer is correct. You can also use a calculator to verify that your solution is correct by plugging in the original equation and the value of x you solved for. If the calculator gives you a value close to the original equation, then your solution is likely correct.
