Proving R^n Can Be a Field: The n>2 Case
  • Thread starter Thread starter dreamtheater
    Field
dreamtheater
Is there a proof that shows if R^n can be turned into a field, for specific n?
Obviously, n=1 is a field, and n=2 can be made into a field (which is just the complex plane.)
So what about n>2?
What invertable, closed, multiplication and division operation are you going to define for n>2?
Even for R^2, your complex numbers, that's a space that's isomorphic with R^2, and is not R^2 itself. You can introduce invertable vector product for R^n (I like the geometric/clifford algebra product for this). But to get invertable and closed with that product you have to combine components of such vector products (ie: complex numbers, and quaternions, or other generalizations of these get by adding grade 0 and 2 components from this larger algebraic space).
it is a theorem that for dimensions three or higher euclidean space cannot be turned into a field, or if we want to be pedantic: for n >/= 3 there is no field isomorphic to R^n.
I saw a proof of the fact in a complex analysis class sometime ago so I don't remember it but it uses (very) elementary methods and as such should be found easily.
I have a small technical problem with the explanation given in 3: in what sense are you asserting that there are no fields isomorphic to R^n for n>=3? Or more accurately, in what category?
I think that it might be better to say - if F is a field, and F is in VECT(R) - cat of real vector spaces - then F has dimension 1 or 2.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
