Racing car centripetal force problem
To calculate the centripetal force acting on a racing car traveling on a circular course, first determine the speed using the formula for circular distance, which is 2πr. Given the radius of 641 meters and a speed of 1.7 revolutions per minute, the velocity can be calculated. The centripetal acceleration is then found using the formula a = V²/r. Finally, the centripetal force is calculated using CF = ma, where m is the mass of the car at 1990 kg. The problem was successfully resolved by applying these principles.
nrc_8706
a racing car is traveling on a circular course of radius 641m at a speed such that it makes 1.7 rev in 1 minute. THe mass of the car is 1990kg. what is the centripetal force acting on the car?
CF=ma=mass*acceleration
a=V^2/r
how do you find v?
you use the fact that its traveling in a circle (distance = 2*pi*r), time can be found from the number of revs per minute.
thank you i figured it out
