Radial component of a velocity vector - cylindrical coordinates
The discussion focuses on determining the radial component of a velocity vector in cylindrical coordinates for a body on a disk. The body is given an initial velocity \( v_0 \) at a known angle, and the challenge is to find the radial component \( v_R \) in the reference frame of the disk's center. The problem requires understanding the relationship between the radial and angular components of velocity in cylindrical coordinates, specifically \( (R, \phi, h) \), while neglecting the thickness of the disk.
  • Cylindrical coordinates (R, φ, h)
  • Vector projection concepts
  • Basic kinematics
  • Understanding of angular velocity
  • Study vector projections in cylindrical coordinates
  • Learn how to decompose velocity vectors into radial and angular components
  • Explore kinematic equations in non-inertial reference frames
  • Investigate the effects of angular velocity on radial motion
Physicists, engineers, and students studying dynamics in cylindrical coordinates, particularly those interested in motion on rotating disks or similar systems.
Matty Mooo
Hi there,
I'm trying to determine the radial component of a velocity vector in a disk. The vector doesn't (necessarily) start from the centre of the disk and can be pointed in any direction. I've attached a .pdf with the schematics - it seems like a simple problem but it has me stumped.
The magnitude and a direction are given (see the attachment).
If someone could direct me in the right direction that would be awesome. I am familiar with cylindrical coordinates, but I just don't know where to start with this one..
Matty.
PS; This isn't homework!
The "radial component" of a vector is the length of its projection onto the line y= x.
Hi,
Thanks for the reply. Although, I'm not sure you understand the problem.
Imagine looking down on top of a disk (with centre at R=0). Then imagine a body, somewhere on the disk (R [tex]\neq[/tex] 0). This body is then given a 'kick' with velocity v0 in a direction determined by the "known angle" in the above attached file. In the frame of the centre of the disk, the body will have a [tex]\phi[/tex] velocity component and an R velocity component. Is it possible to find vR, the radial component of the body's velocity, as measured in the frame of reference of the centre of the disk?
The above problem is working in cylindrical coordinates (R, [tex]\phi[/tex], h), where h, the thickness of the disk, is neglected.
Apologies if I'm not explaining myself properly!
Matty.
PS; There are some other variables I can provide. Also, even a small velocity approximation would suffice for now.
  • · Replies 18 ·
19K
  • · Replies 30 ·
