Radial Suction Fan Design & Equations
The discussion focuses on designing a fan that sucks air radially and blows it axially, highlighting the challenge of finding appropriate equations for this configuration. The original poster seeks formulas to determine the optimal blade angle and RPM for achieving the desired airflow direction. Suggestions include using an axial fan with ducts and inlet guide vanes to facilitate radial air entry before axial flow. The poster has conceptualized a design involving a radial fan within a cage to maintain neutral airflow and seeks literature on the physics of air particles on the blades. Overall, the conversation emphasizes the complexity of radial inflow fan design and the potential for alternative solutions.
Puntilla
Hi, I've been considering the design of a fan that sucks air radially and blows axially to resolve a technical problem of a machine. I've looked around for the equations governing the air particles and the angle of the radial blades (angle between a flat blade and a radial line) of the fans, but those equations are mostly developed for radial blowing fans and used to determine the pressure and velocity of air coming OUT radially. I would like to find a formula to determine what blade angle and RPM combination would cause air to be sucked radially and blown axially. Also, how to link constant RPM to the acceleration, velocity and displacement of a particle on the surface of a blade. Any help with this would be welcome... I tried to derive the equations based on free body diagrams, but I guess my physics are a bit rusty!
Thanks in advance for your time and help.
Regards,
Puntilla
A radial inflow fan is a very difficult thing to design .
An easier solution would be to use an axial fan and use ducts and inlet guide vanes to allow air to enter fan housing radially before passing through fan axially .
Hi Nidum, thanks a lot for your reply. I had a similar thought and already conceptualized something along those lines (see image below). As you can see, I've attached the radial fan (on the right) to a cage with "hopefully" neutral air flow. So along the lines of what my original question was, I would like to understand the physics of an air particle resting on one of the blades of the "neutral" airflow cage, so I can make design it with either neutral or slight radial inflow. Do you know of any literature to help me here?
An Axial fan is basically a kind of compressor that can enhance the air pressure flowing through it. The range of axial flow fans is very wide and it may vary from a low or medium pressure fans to high pressure fans.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
