Radiant Energy Absorbed by Person's Head with Hair
In summary, the problem involves finding the radiant energy absorbed per second by a person's head covered with hair while standing in the shade at a temperature of 28 degrees C. The emissivity of the hair is given as 0.85 and the surface area is 160 cm^2. The correct equation to use is P=emiss*area*sigma*T^4, where T is the temperature of the surroundings. After solving, the answer should be 6.3 J/s, not 13.9 J/s as originally calculated.
grandprix
28
A person is standing outdoors in the shade where the temperature is 28 degrees C. What is the radiant energy absorbed per second by his head when it is covered with hair? The surface area of the hair (assumed to be flat), is 160 cm^2 and its emissivity is 0.85.
Qrad = emiss*area*sigma*T^4
.85 is the emissivity, so the absorptivity is .15
The temperature of the head originally is 98.6 degrees, or 310 K
so
Qrad/T = (.16 m^2)(.15)(5.67 X10^-8)(310^4 - 301^4)
Not sure if this is right?? I am coming with an answer of 13.9, but the book says the answer is 6.3 J/s
The absorbed energy per second is given by P=emiss*area*sigma*T^4. T is the temperature of the surroundings, which is 28 degrees in this case; it is not the temperature of the body doing the absorption!
You apparently thought P=absorptivity*area*sigma*(temperature of head)^4, which is not correct.
Note that absorptivity = emissivity.
Also, double-check the conversion from cm^2 to m^2.
What is radiant energy?
Radiant energy is a form of energy that is transmitted in the form of electromagnetic waves, such as light, radio waves, and X-rays. It can also refer to the energy emitted by heated objects, such as the sun.
How does radiant energy affect a person's head with hair?
Radiant energy can be absorbed by a person's head with hair just like any other object. The amount of radiant energy absorbed depends on factors such as the color and thickness of the hair, as well as the intensity and wavelength of the radiation.
Is radiant energy absorbed by a person's head with hair harmful?
In small amounts, radiant energy absorbed by a person's head with hair is not harmful. However, if a person is exposed to high levels of radiation for an extended period of time, it can cause damage to the cells in the body.
Can hair protect a person from radiant energy?
Hair can provide some protection from radiant energy, depending on its thickness and color. Darker and thicker hair tends to absorb more radiation than lighter and thinner hair. However, hair cannot completely block all forms of radiation.
How can one protect their head and hair from absorbing too much radiant energy?
To protect your head and hair from absorbing too much radiant energy, you can use protective gear such as hats or helmets. You can also limit your exposure to sources of radiation, such as the sun or electronic devices.
10K
